Old 1st June 2009, 01:56 AM   #1
Default Simple accelerometer and tilt sensor
This would make a good accelerometer. How it works is it has three mirrors in it two on the led side of the flaps. And one on the bottom, with the LDR facing down out side of the flaps. When the car or what ever you put it on
accelerates they move back by the amount of force to make your car move. Which angles the light from the led towards the LDR. Which lowers the resistance by how much force is applied. You could also use it for sensing tilt.
I made one with ball and spring to see if the car moved but with flaps and mirrors you have better precision if you wanted to use it for tilt. It starts at 112K and gos down to 20k like turning a adjustable potentiometer very good control.
I guess people think this is big or hard to make it is only a 1/2 by 1/2 by 1 1/2 inch the mirror is made of
paper you get it at hobby shops. The flaps are hinged on a piece of copper wire with copper foil and the mirror glued to it an I coated it with solder for more weight. Here a pic of the first one I made not to good looking but it worked as good or better then what you can buy. And it cost less then a dollar to make.
Here shows how the adc values change on LCD
be80be is offline
Old 1st June 2009, 03:17 AM   #2
Neat idea, don't know how durable it would be though.
Mike
birdman0_o is offline
Old 1st June 2009, 03:28 AM   #3
be8, it might be nice if we could see the actual sensor in that video, also it's going to be so mechanically sensitive it couldn't be used in any situation where there'd be high shock forces or vibration. Accelerometers are not that expensive.
straight answer, har har."
Sceadwian is offline
Old 1st June 2009, 03:54 AM   #4
You can tell shock same way sparkfun 27.00 Accelerometers dose it calibration. Acceleration is shock like the force that pushes you back in the seat when you hit the gas Or the shock of some one hitting your car in the rear end. Still Acceleration.
I was raising it with my hand. I wanted to see the voltage change more then watch it raise. I could fix it so vibration is not a factor. It should hold up good. I was thinking about using it where there is not much vibration
be80be is offline
Old 1st June 2009, 02:08 PM   #5
I like what you are doing with DIY sensor but here size works against you.
The force due to acceleration increases with an object's mass. force = mass x acceleration
The larger a sensor is the more sturdy it has to be.
Sturdy things tend to be massive.
BCHS/3v0's Tutorials
3v0 is offline
Old 1st June 2009, 03:57 PM   #6
This is not that big
And from what I tested so far mine can do the same things it can it's just a little faster and it's decoder is built in mine a pic.
Use that one if you want to it can handle 1000 g Shock Survival not powered up and 500g with the power on. But from what
I tested mine would win hands down at tilt. That's not why I made it I like it.
be80be is offline
Old 1st June 2009, 04:53 PM   #7
Good point my testing rig i glue it on with hot glue. I was getting the same voltage reading got my cam out and it started changing. The glue I had holding it to the arm didn't hold up lol
be80be is offline
Old 2nd June 2009, 07:30 PM   #8
Sturdier things are more massive, but they also fall a lot harder. You should now work on a home-built vibrating gyro.
dknguyen is offline
Old 3rd June 2009, 02:30 AM   #9
This would be fun Building a Balancing Scooter I have most of the junk to make it and I think my sensor would work out find to help keep you up right.
be80be is offline
Old 3rd June 2009, 03:27 AM   #10
Accelerometers don't work for things like that. As soon as you accelerated forward, the platform would knock you on your back (or vice versa).
dknguyen is offline
Old 3rd June 2009, 03:50 AM   #11
You no I always jump the gun . I was thinking about tilt control. It has two sensors and you could find the middle. It can tell if you tilt forward or backwards. With some fast Adc I'm sure you could keep it upright.
be80be is offline
Old 3rd June 2009, 04:13 AM   #12
You still would need a gyro. ADC speed isn't the problem. It's that the acceleration when moving would skew the gravity reading making it think the ground is not quite where it actually is. Two sensors don't help either because acceleration skews both sensors in the same direciton.
dknguyen is offline
Old 3rd June 2009, 04:15 AM   #13
I don't have any good links to gyro when you google you get food I done ate Lol. I see what your saying But I think there a way to make it work like I'm thinking. If it tilts back one LDR will increase in voltage and one will decrease in voltage. That will tell which way your moving. Now if i compensate for acceleration I could keep it upright. May work but if not still some thing to do. I like the ideal of a gyro but it would have to be big to keep me upright.
be80be is offline
Old 3rd June 2009, 04:22 AM   #14
I don't understand.
You have links? Or do I have links?
dknguyen is offline
Old 3rd June 2009, 04:36 AM   #15
I didn't put don't in there Do you have any good link's
be80be is offline
accelerometer, sensor, simple, tilt
Tilt Sensor / Shock Sensor Mobile Phone Call Motorcycle Alarm lusitanv Electronic Projects Design/Ideas/Reviews 2 30th May 2009 12:36 PM
Tilt sensor MikeMl Robotics Chat 4 2nd April 2009 01:06 AM
Tilt Sensor jnnewton Electronic Projects Design/Ideas/Reviews 2 2nd April 2008 01:53 PM
tilt sensor neel45 Electronic Projects Design/Ideas/Reviews 6 22nd August 2004 05:25 PM
tilt sensor koyeh182 Electronic Projects Design/Ideas/Reviews 6 4th January 2004 03:23 AM
