+ Reply to Thread
Results 1 to 9 of 9
Thread: drum robot...argggg
  1. #1
    ale2121 Newbie
    Join Date
    Dec 2008
    Posts
    4
    Default drum robot...argggg
    hi all.
    I'm building a simple mechanism to play a drum. I've got a 555 timing circuit to control the speed of a motor. first i built it like this (beware it's noisy):
    YouTube - Drum Video
    but, i don't like how erratic the mechanism is.
    so i rebuilt it with a roughly 4 inch cam i made out of cardboard mounted directly to the motor. the drumming is less erratic now, except that the motors are burning out (i think). My guess is they're cheap motors, AND it's an off center load. Also, in both cases, I have to turn the PWM way up to get the motor going, then turn it down to where i want it. So, do i just need higher torque? or a different mechanism entirely? I like the cam because it allows gravity to come into play, but I'd also be willing to try some linkages to make linear movement instead. Unfortunately, I don't know how to make linkages without a prototyping machine. Also, I'd super love some worm gears that would fit my situation, again, don't know where to get them, or how to decide which ones I need. Anyone have any advice? I'd really love it.
  2. #2
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,043
    What about doing this electronically?
    It's pretty easy to make a drum sound using an oscillator with the gain set too low for it to oscillate.
    if I know the answer.
  3. #3
    ale2121 Newbie
    Join Date
    Dec 2008
    Posts
    4
    no, i've got that already on another instrument. I really want mechanical things. thank you though.
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,775
    Quote Originally Posted by ale2121 View Post
    Considering they were doing it mechanically, or by steam power, back in the 1700's and 1800's, if not before, it can't be that hard to do with modern electronics.
  5. #5
    ale2121 Newbie
    Join Date
    Dec 2008
    Posts
    4
    i agree, it's not that difficult, as long as i can get my hands on the parts. anyone know a good place to get either worm gears or linkages that will fit hobby motors?
  6. #6
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,701
    Blog Entries
    5
    Lego Parts
    Bill
    Smart Kits build Smart People
  7. #7
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,043
    A solenoid?
  8. #8
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    The thing about drums is the weight of the stick is what does most of the work especially on faster drum rolls. Usually a human hand is simply acting as an elastic device and it's being fed momentary pulses from the muscles to give a little bit of energy on the up stroke. So I'd recommend using a jig of some kind holding the drum stick but giving it some flexibility and then somehow connect a motor to that to provide impulses. The travel does not need to be very far.
    Looking at your drum video again I think you might get significantly better results by simply attaching a rubber band to the drum stick in such a way that it provides a bit of tension (very light but play around with it) to hold the drum stick to the drum itself. Then you cam arm will have better luck driving it.
    straight answer, har har."
  9. #9
    ale2121 Newbie
    Join Date
    Dec 2008
    Posts
    4
    I have a bunch of solenoids, but they hold a charge for too long and won't release when the electricity turns off. I don't really know how to rate them, maybe these just aren't the solenoids I need? but as they stand they won't work for what I need.
+ Reply to Thread
  1. Need Help Putting LED Lights on Drum Pad
    By LiquidOrb24 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th September 2009, 02:40 PM
  2. Drum machine....soldiering gone bad
    By rapper_eater in forum Repairing Consumer Electronics
    Latest: 18th April 2009, 03:28 PM
  3. Electronic drum kit
    By conchord in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th March 2009, 11:22 AM
  4. Making an Electronic Drum Module..
    By Peter_wadley in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th April 2007, 05:41 AM
  5. Drum triggering circuit...
    By Dr.EM in forum General Electronics Chat
    Latest: 29th December 2004, 09:08 AM
Tags for this Thread
