+ Reply to Thread
Results 1 to 11 of 11
Thread: accurate on spot breaking
  1. #1
    mokvlcc Newbie
    Join Date
    Apr 2009
    Posts
    5
    Default accurate on spot breaking
    hi guys,
    i am making an autonomous robot that should stop at exact positions.....i hv avoided the problem of 90 degree turns by using four roller wheels in perpendicular directions(along the sides of the square robot)
    nw my question is...
    what's the best method for accurate breaking???
    i hv noticed tht there are different types of roller or omni directional wheels...which one is better??(three rollers,four rollers...or more)
    is it ok to use four different motors or is it better to use two motors with two shafts???
    i need the motors to move in two opposite directions what is the best way to accomplish that???
    is it better to use a DC motor or a stepper motor???
    are there any other types of motors tht u recommend??
    my personal idea at the moment is to use four DC motors and the three rollers omni-directional wheel....and alternating the direction through inverting the input to the motor......n still haven't figured out a way for one spot breaking
  2. #2
    Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    Drive both sides of the H bridge Low OR high to stop it immedately.
    You should probably stick to regular robot drive wheels and have encoders on them for accurate movements.
    IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
  3. #3
    mokvlcc Newbie
    Join Date
    Apr 2009
    Posts
    5
    thanx krumlink for the fast response.....i appreciate ur recomendations
  4. #4
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    Use a DC motor for ease of interface, or a stepper motor for very precise motions (harder interface). Use a motor per wheel.
  5. #5
    duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    Quote Originally Posted by Krumlink View Post
    DON'T DO THIS!!!! This will short out the power supply and blow out drive transistors! Turn on both the high side drivers or both the low side drivers to brake. Never, ever, turn on all four drivers of an H bridge at the same time.
  6. #6
    3v0
    3v0 is online now
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    You need to read Krumlinks post again.
    Drive both sides of the H bridge Low ****OR**** high to stop it immedately.
    stars mine
    Quote Originally Posted by duffy View Post
    BCHS/3v0's Tutorials
  7. #7
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    how is that different then what I said?
  8. #8
    mokvlcc Newbie
    Join Date
    Apr 2009
    Posts
    5
    dn't worry guys i got ur point however u wrote it..........thanx alot for ur replies.....i greatly appreciate them
  9. #9
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    I'm sorry, Krumlink, I thought you were suggesting turning on both sides at once.
  10. #10
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    Turning on all one side would kill it. Turning on the same pair (T1, T4) (T2, T3) will electrically brake the motor, hence high braking (T1, T4) turns both sides of the motor High. Low braking (T2, T3) turns both sides low.
  11. #11
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    I see what you thought I meant.
+ Reply to Thread
  1. Is this a breaking DC socket?
    By revans in forum General Electronics Chat
    Latest: 8th December 2008, 05:48 PM
  2. Breaking DC motor
    By mahmoud shendy in forum General Electronics Chat
    Latest: 30th October 2008, 05:08 AM
  3. Record-breaking battery
    By t.o. in forum Chit-Chat
    Latest: 22nd January 2008, 08:36 PM
  4. Spot!
    By epilot in forum General Electronics Chat
    Latest: 24th January 2007, 02:13 AM
  5. Breaking for spares
    By tansis in forum Feedback/Comments
    Latest: 1st September 2003, 07:19 PM
Tags for this Thread
