+ Reply to Thread
Results 1 to 5 of 5
Thread: Electric wheel chair, question about amps
  1. #1
    joshua17ss2 Newbie
    Join Date
    Mar 2008
    Posts
    106
    Default Electric wheel chair, question about amps
    i got an electric wheel chair, and ive been working on modifying it, i think that the original motor control is totally dead, so im working on desinging my own.
    The motors are 24 volt DC motors. their are 2 12 volt 50 amp batteries.
    my question is do the motors actually run on the 50 amps, or is that more for longer battery life ? Maybe only uses 50 when loaded down with a person, or something like that.
    i want to find 24 volt 50 amp RC ESC w/ reverse but my time spend on google has given me few results.
    i would also like to know if either there are ESC that would meet my needs, or if i could use a much lower amp ones.
    any information would be appreciated.
  2. #2
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    There is no such thing as a 50 amp battery.
    50 amp hour maybe, it has nothing to do with the motor itself though. 50AH's means it will provide the equivalent of 50 amps for 1 hour. BUT amp hour ratings on lead acid batteries (what you're using) are based on a 20 hour discharge. So you can only draw 2.5 amps off that battery and still get a 50AH rateing on the battery. More than 2.5 amps at a time, and the capacity is lower from internal losses. You need to determine what the TRUE current draw under a typical load is going to be for your motor before you can determine what kind of ESC you're going to use.
    straight answer, har har."
  3. #3
    Willbe Good Willbe Good Willbe Good
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    Quote Originally Posted by joshua17ss2 View Post
    The Web tells me 5 hours of W/C operation between charges is reasonable so this would put motor current draw at ~10A.
    To measure max current I'd load the chair with 300# and go up a wheelchair access ramp; these ramps are designed so that most or all W/Cs can go up it.
    The reliability of your control circuit must be very high because a life depends on it.
    If the rated motor current is I and you use PWM for the motor control, exceeding 5I will probably demagnetize the motors.
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,762
    You can't really specify the load requirement for a motor, because it varies massively over it's range of use - but consider a much smaller, far less powerful, motor in an R/C car can easily take over 100A on peaks, and needs a substantial ESC.
    For reliabilty reasons alone I would suggest you replace the controller with the correct type, unless you're just ripping the motors out to make a robot wars type machine?.
  5. #5
    joshua17ss2 Newbie
    Join Date
    Mar 2008
    Posts
    106
    Robot type war machine is about how i would describe it. im shooting more for simple Robotic base.
    i still have the original motor controller, and im still trying to bring it back to life, im waiting on a new hex inverter chip as i think due to a wiring mishap it got burnt up.
    so im gonna replace it, and try again, i already bypassed the brakes on the motors, so they now turn off when the power is applied for now. i just want to get the wheels turning again.
    At the moment i just want to get the whole base responding to an RC remote. then move on to a computer.
+ Reply to Thread
  1. Eleltronics goof needs help making a 4 wheel electric scooter...
    By sugateddy11 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th March 2009, 03:30 AM
  2. motor question for pottery wheel project
    By cwickham in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th December 2008, 01:24 AM
  3. Noob question. 12 volts, 25 amps
    By tieme in forum General Electronics Chat
    Latest: 24th October 2008, 08:46 PM
  4. Question: Difference between comparators and op amps?
    By speakerguy79 in forum General Electronics Chat
    Latest: 2nd January 2008, 07:35 AM
  5. design circuit that controlles a wheel chair
    By dudy in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th April 2005, 07:05 PM
Tags for this Thread
