Old 1st April 2009, 06:50 PM   #1
Default Tilt sensor
I'm looking for an single or two-axis tilt sensor that will produce voltage(s) proportional to deviation from gravitational vertical. Size, operating voltage not important. Should have reasonable accuracy ±10 degrees. It will never tilt more than that (unless it tips over )
MikeMl is offline
Old 1st April 2009, 09:07 PM   #2
Accelerometer IC.
Forget about the sinusoidal relationship of gravity with incliniation...below 20 degrees deviation from zero, the sine function is linear, so is the cosine function except centered around 90 degrees.
dknguyen is offline
Old 1st April 2009, 10:17 PM   #3
Electrolytic tilt sensors...Electrolytic Tilt Sensors
Ken
KMoffett is offline
Old 1st April 2009, 10:27 PM   #4
Those electrolytic sensors would be a more straightforward solution, but last time I checked, Spectron quoted me at $260 for a single module (that's a dual-axis sensor mounted on a PCB module with all the temperature compensation and excitation and signal conditioning). They are much larger and more delicate than an accelerometer, but more tolerant to continuous accelerations and very very accurate from -90 to 90 degrees.
dknguyen is offline
Old 2nd April 2009, 01:06 AM   #5
SparkFun Electronics - Accelerometers
straight answer, har har."
Sceadwian is offline
sensor, tilt
Tilt Sensor jnnewton Electronic Projects Design/Ideas/Reviews 2 2nd April 2008 01:53 PM
Tilt Sensor Project ironside82 Electronic Projects Design/Ideas/Reviews 13 29th March 2008 03:46 AM
Ideas for a tilt sensor DannyBoy99 Electronic Projects Design/Ideas/Reviews 32 24th October 2006 07:42 PM
tilt sensor neel45 Electronic Projects Design/Ideas/Reviews 6 22nd August 2004 05:25 PM
tilt sensor koyeh182 Electronic Projects Design/Ideas/Reviews 6 4th January 2004 03:23 AM
