Old 6th March 2009, 01:24 AM   #1
Default Where to get parts (tiny motors)?
I'm looking to get some small quantity (around 1000) of small dc motors, and I'm having trouble finding a good supplier. What I'm looking for are motors that are tiny (less than 8mm diameter, less than 16mm length).
I was wondering if anyone had any good contacts, or ideas where I could get something like that (I've found a few suppliers, but so far they're far from reasonable -- I got one quote for $153 per motor )
John
julvr is offline
Old 6th March 2009, 02:27 AM   #2
Vibrating Motors you can get them here 98 cents
be80be is offline
Old 7th March 2009, 01:37 AM   #3
Thanks -- those are much more reasonable prices. Just one question -- what exactly does the term 'vibrating motor' imply?
John
julvr is offline
Old 7th March 2009, 02:04 AM   #4
They have metal weight on them that make them vibrate you can remove it but they sell them with out it to at the site I posted but take a look here it tells a lot about small motors
Robot Room - Removing Weight From Tiny Vibrating Motor
be80be is offline
Old 7th March 2009, 04:38 AM   #5
Be wary of those, the weights look like they're press fit on, they may not be removable without damaging the motor. The one's that look like discs are completely enclosed and I don't think it's practical to modify them as normal rotating motors, I've never taken one apart though as I only have one, and it makes too nice of a vibrating motor to destroy. Keep in mind, the voltage and RPM rating on these motors can be highly variable and they are NOT ment for high speed constant use.
straight answer, har har."
Sceadwian is offline
Old 8th March 2009, 03:01 PM   #6
OK, since I'm ordering 1000 of these, weight removal is not really an option. I also need motors that are meant to run continuously (1h intervals once per day), and that can be reversed...
Does anyone know if the TPM2 can run in reverse? Does anyone know of any other motors that might be a smidgen less expensive?
John
julvr is offline
Old 8th March 2009, 04:14 PM   #7
DC Motors they don't just sale vibrating pager motors and they have them with the weight removed any dc motor is
reversible.
I'm ordering 1000
then you need to join GlobalSpec – Engineering Search & Industrial Supplier Catalogs then you can find what ever you need
be80be is offline
motors, parts, tiny
Parts count vs. parts cost - Manufacturing question mdwebster Electronic Projects Design/Ideas/Reviews 6 30th April 2008 10:58 PM
PWM control of BLDC motors (brushless DC motors) jhanus Micro Controllers 6 1st October 2007 05:32 PM
shunt motors, series motors...dc motor fabbie General Electronics Chat 5 19th December 2004 12:27 AM
tiny IC computer General Electronics Chat 5 6th April 2004 07:30 PM
Robot bases, motors and parts Jerran Robotics Chat 5 3rd March 2004 12:28 AM
