Old 10th February 2009, 09:30 PM   #1
Default Testing Servos
Hi again, I'm trying to test my servos to see if they work properly (the model is hs-81 servo), I'm using a Agilent 33220A Function/Arbitrary Waveform Generator but I'm not entirely sure what I'm doing wrong since as soon as I turn the generator output on the servo performs a full spin and starts jerking at max force.
I'm sure that the problem is with the generator and the values that I'm using, can you guys advice me of the specs that I need to set in the gen so that the servos work properly.
Thanks for your time.
Azkart is offline
Old 11th February 2009, 12:09 AM   #2
How about giving a clue as to the values/waveform you are generating? Did you put a sope of it to confirm?
John
jpanhalt is online now
Old 23rd February 2009, 02:00 PM   #3
It's like 1.5mS "on" and 20mS "off" to get center.
duffy is offline
Old 24th February 2009, 07:22 PM   #4
Whats a servo: A quick tutorial
that will give you the details on PCM control of servos.
If you plan on testing a lot of servos, build one of these:
556 Based Servo Exerciser
bubba_blazer is offline
servos, testing
servos danielsmusic Electronic Projects Design/Ideas/Reviews 17 11th November 2009 07:04 AM
adc two servos 12f675 jeremygaughan Micro Controllers 9 19th May 2009 02:01 PM
Multitask servos with PIC antkids Robotics Chat 11 6th January 2008 02:00 PM
8 or 16 Servos using PWM module Mike, K8LH Micro Controllers 0 13th May 2007 03:14 PM
Servos Jevon Robotics Chat 10 14th November 2006 06:33 PM
