Old 8th January 2009, 10:10 AM   #1
Default Three legged robot..lil help pls
hey ,
I have a competetion coming up..n i have to make a three legged robot..which should
1)walk like a human i.e lift its leg up and down.
2) make a right or left turn
it could even be two legged.
i have checkd online..hey use a gui to calibrate the movement and serial cable
can we write the entire program on a chip which doesnt require calibrating.?
i was thinkin of using the components in my bluetooth mouse for the control.
what would be the basic requirements?.i have knowledge in atmel 89c51/89c52programming.
pls suggest ideas...thank you very much.
puremobi is offline
Old 8th January 2009, 12:40 PM   #2
Sounds very difficult for a beginner. Wheeled robots are much easier.
Bill
Smart Kits build Smart People
Old 24th January 2009, 11:15 PM   #3
hi blueroom,
I have a doubt with PWM and servo,
Should i continously send 20ms delay with 1ms to get clockwise rotation?..
what about the 90 degrees?..it says 1.5ms
so should pulse be continous to the motor?..or for a define number of cycles?
puremobi is offline
Old 25th January 2009, 09:32 AM   #4
The pulse has to be continuous.
Nigel Goodwin is online now
Old 25th January 2009, 10:08 AM   #5
Am curious as I am sure so are many others who have viewed this thread,
how have you or intend to solve the problem of making it balance?
The Mad Professor is offline
Old 26th January 2009, 02:22 PM   #6
thanks for reply..
iam sorry ,
iam using two threads for the same doubt.
professor,i didnt get ur question at all..
Basic Servo Motor doubt - Electronic Circuits Projects Diagrams Free
puremobi is offline
Old 26th January 2009, 06:29 PM   #7
Default Equilibrium - it's a question of balance
Are all three legs to be moved independently using servo motors ?
True three legged robots are notoriously difficult to get right, consider the classic robot of science fiction the 'Tripod' from HG Wells novel 'War of the Worlds'. Paramount film studios have twice thrown a great deal of money at this problem once in 1953 and again in 2005. The BBC special effects people also had a look at the problem for the series 'Tripods' in 1984 and said no way it can be done.
The problem is the moment you try to lift one leg up it falls over in that direction, bipedal (two legged) robots get around this by leaning over thus shifting weight to the stationary leg while the other one moves. With a tripod however the arrangement of legs means that the center of gravity is always going to be in the wrong place for walking.
Now if you could devise a way to change the center of gravity, the same way high wire walkers do , then it could amble along quite nicely.
Old 26th January 2009, 07:23 PM   #8
nice..three legs gonna be big flop then..
had a tough time with two legged robot..my friend had bought a lynxmotion robo with expandable accesories..
great issue with weights..
iam goin with the six hexa pod now..
requirin at least 12 servos i guess..
puremobi is offline
Old 27th January 2009, 10:20 PM   #9
Default Don't abandon hope
Don't abandon hope, the idea is not flawed but the technology is.
The small geared servo motors just cannot move fast enough to beat the pull of gravity.
As Thomas Edison famously said:
Build A Better Mousetrap And The World Will Beat A Path To Your Door
The same could be said of servo actuators, you can get high speed ones but they are large, use lots of power and typically found in industrial machine tools. Amateur robot builders meanwhile are stuck trying to make do with a geared servo mechanism whose design has changed little in over two decades.
Old 27th January 2009, 10:36 PM   #10
Wait - don't give up - three legged robots are BITCHIN'!!! Look at this page -
Swashbot
That doesn't look too hard to build, and wins points for style, if not speed.
duffy is offline
Old 28th January 2009, 07:12 AM   #11
Default Scuttle and Stride
STriDER - Can you run faster than it ?
STriDER Tripedal Dynamic Experimental Robot: Science Fiction in the News
Old 28th January 2009, 07:21 AM   #12
Swashbot
Wow! Definitely not a speed demon but so much personality. (Jeez. I think becoming a father has made me into a hopeless cheeseball). It's guys like that who make me sad that movies are headed so firmly toward CGI instead of animatronics. Maybe he can get a job at Disneyland.
Torben
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Old 28th January 2009, 07:27 AM   #13
Originally Posted by The Mad Professor View Post
Seeing as the makers were impressed that it managed one step, I could probably outrun it, yes. But a fully debugged unit would be fun to watch. A thousand of them running over a hill toward me would scare the bejeezus out of me.
For some reason the motion of that thing made me think of this:
I hope STriDER's programmers take this into account.
Torben
Torben is offline
Old 28th January 2009, 11:35 PM   #14
well,it definetely seems possible n more interesting than the six legged..
iam clearin out some questions with runnin a servo..when its done..i will march forward..
strider ....they can get scary ,jus so if u watched other videos of strider.;s
puremobi is offline
Old 28th January 2009, 11:38 PM   #15
in the swashbot..the 'shapelock plastic ' used is pretty cool..best fast solution
puremobi is offline
legged, pls, robotlil
Help with a 3 legged phototransistor chrisgielens Electronic Projects Design/Ideas/Reviews 2 3rd November 2008 03:56 AM
Building a four legged bot. Velvet Leopard Robotics Chat 5 11th January 2007 04:39 PM
Robot Efficiency & other Robot stuff williB Robotics Chat 56 1st May 2005 04:35 AM
legged robot khangura_manjot Robotics Chat 3 16th April 2005 11:56 AM
LEGGED ROBOTS THAT CAN BALANCE subhasis Robotics Chat 0 27th January 2005 11:03 AM
