I am making a new bot and using two geared DC motors. In my last bot I used steppers so I did not run into this kind of problems. But now my circuit is flooded with interference when the motors turn on. I actually killed a PIC mecause of that. So now I bought an oscilloscope just to sort this out. As I have never used an oscilloscope before, the instrument is still new to me. Ok, so I have two ceramic capacitors, 100nF each, connected between each motors supply pins. And connecting the oscilloscope probe to the positive of the circuit, and the probe ground to the circuits ground, oscilloscope voltage range set to 20mV and Time/DIV to 1ms. The image I am seeing is this: Now I have tried 220nF and 1uF capacitors across the leads, but the results are about the same. So how do I get rid of that motor noise in my circuit?
__________________ Here...let me improve it for you! *Puff of smoke* ....oops... | |
Do you have blocking diodes on your motors
Yes I do. This is my motor control board circuit: There is an error on this schematic which I have corrected. I am now using pull-downs on all I/O lines.
__________________ Here...let me improve it for you! *Puff of smoke* ....oops... Last edited by raitl; 21st December 2008 at 08:07 PM. | |
Take a look at this site Reduce Motor Noise | |
Thanks a lot! I managed to get the interference down to 40mv now. Going to solder a new PIC into the circuit tonight and see how it will behave.
| | #6 |
Put you socket in for your pic
| | #7 |
The socket rises the PIC too high. Even though I have a low profile socket. It is a tight fit as it is
| circuit, interference |
| TV interference | mstechca | General Electronics Chat | 6 | 11th July 2005 01:02 PM |
| TV/radio interference | comatoes | General Electronics Chat | 7 | 24th May 2005 10:31 PM |
| RF interference | ulot | General Electronics Chat | 14 | 21st April 2005 10:53 AM |
| interference question | mstechca | Electronic Projects Design/Ideas/Reviews | 2 | 19th January 2005 07:00 PM |
| CD player interference | jrz126 | Electronic Projects Design/Ideas/Reviews | 9 | 8th October 2004 12:43 PM |
