Pick another project you can afford in skillz, time and money.
the thing is i cant change my project and the cost factor is different thing cause i think 200$ for the whole project is enuff and i hav the skills just the program is a part which is difficult and i am not saying tht some body rite the whole prgram for me if some could just give me part of it so i can understand and write the rest and take further help with it
Does your instructor approve of this?
Apptove of ?
here i found somethign more see if this could help u out
You first load 00h to ports P0 and P2. Set for a long interrupt period of 18240 usec. During this period read all ADC channels and set up 16 pairs of registers with appropriate bit values.
On receipt of interrupt, change the interrupt to 32usec. For the first 39 interrupts load P0/P2 with 0ffh and for the next 16 interrupts load each pair of 16 register pairs to P0/P2. Go back to Reading ADC process from the beginning and repeat the cycle.
But not sure of it cause the time period i need it to run 50hz 20ms and the servos have to move between 0 to 90 degrees
I am posting a c code for a project on rc servo motor used to control camera using a adc and some micro controller with a joystick my project kinda has the same build so can u like remove the extra parts and show me wat i will actually need i found this long back
Take a look here divit. This is a single version of what you need and will be a great big push in the right direction. Microchip are good at providing free samples so the chip won't cost you :0
Gordz i dint understand u and t i thnik u 4got to post wat you are showing me and i a ready to use another IC only if its in the 89 series or 8051 series cause we only allowed to use them
Rushing off to work.
RC-CAM Projects: R/C Servo Tester
This guy wants people to try hi project, single channel but exactly what you need.
Thanks alot gordz this might help out alot but the problem is his progra is in hex form and impossible to tweak it cause he hasnt given the c program to it so i some 1 could help me out how to convert the following file and also he has used a PIC12C508A is it possible tht some 1 could help me program a 89S52 with this
We never have time to do it right; but we always have time to do it over.
Sorry divit but I can't help much more. I do .asm not C and I only use PIC micros these days. Try Google.
