hi all, i got this old project from my advisor its an electric cart it has two dc motors, each has its own driver circuit on the back they are connected to an analog circuit and a joystick i replaced the analog circuit with a PIC16F877A ucontroller IC and I kept the joystick and used it to send signal to the uC anyway, now I have to find a speed sensor that I can use to measure the speed and display it on LCD any ideas for the sensor? I cant use a hall effect sensor cause i have no place to fit it on the project! | |
You just need a sensor to detect the wheel rotation, hall effect, reed relay, IR beam (either broken or reflected) - there are loads of different methods.
how is the IR sensor work? do I point it at the wheels and it detects motion? what is making the task a bit difficult is that I cant attach anything to the wheels and also the cart will be used outdoors, so, dert getting on the wheels has to be taken into concederation | |
Any optical system has to be kept clean.
| | #5 | |
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ | ||
| | #6 |
| | #7 |
What about the wheels - tyres are only part of it.
| | #8 |
hi, you can calculate the speed using normal ir sensors(and the method is very economical and cheap) step 1>build an ir sensor step 2>make sure your wheel has 4 holes in them step 3>on one side of the wheel make sure you keep ir sensor aligned to the holes and on the other side a white sheet so that a signal a can be sent back to the ir when a hole is detected. so one rotation the ir sensor goes high 4 times. if the sensor goes high for 32 times,the number of rotations are 8 (32/4) regards. my first bot Last edited by junior000; 17th October 2008 at 04:06 PM. | |
| project, robot |
| Robot Project !!! | watzmann | General Electronics Chat | 3 | 2nd March 2008 10:29 PM |
| Project P24 Robot Arm | Mmouse | Electronic Projects Design/Ideas/Reviews | 1 | 6th January 2008 11:10 PM |
| Robot Project | Kingpin094 | Robotics Chat | 20 | 12th October 2006 11:53 AM |
| Help in robot project | dx_2k5 | Robotics Chat | 7 | 16th August 2006 06:28 AM |
| help with robot project | bikutoruzan | Robotics Chat | 1 | 14th June 2004 04:32 PM |
