Old 22nd February 2004, 12:15 AM   (permalink)
Experienced Member
Super Mario is on a distinguished road
Send a message via MSN to Super Mario
Default Wheels/Motors/...
I want to build my first line following robot.
I ordered my first PIC and programmer, and I got tutorials which were really good for my level , and I have some electronics knowledge.
Now I need to know about motors , can anyone explain to me in breif how exactly the motors will work in mechanical point of view , for example,how many motors I will need and how to make the robot move right and left..etc , and should I start learning about motors starting from the basics or is it okay to start with a specefic type ( i hear ppl talking about stepper motors)?
I\'m a newbie that needs help =)
Super Mario is offline   Reply With Quote
Old 22nd February 2004, 10:06 AM   (permalink)
Experienced Member
andy257 is on a distinguished road
Send a message via MSN to andy257
Hi there,
sorry to hijack your post but could i ask where you got information on programming PIC. I wish to learn how to do this also.
cheers
andy
andy257 is offline   Reply With Quote
Old 22nd February 2004, 11:04 AM   (permalink)
Experienced Member
pike is on a distinguished road
In response to andy: Head over to www.winpicprog.co.uk from there you can find tutorials on learning how to program PICs.
Servo motors are motors that have steps inside them, that means you have to pulse electricity to the motor at different wires. This allows you to control the position of the shaft very acurately.
say i have a servo motor with 60 steps: 360 degrees/60 steps = 6 degrees in motion per step. To make to motor run a full revolution i need to pulse 60 times to the motor.
The only thing that i see servos can do in a car is control the steering mechanisms. everything else can be powered by a normal DC motor.
you could use the skid-steering method of steering, which is much easier. Military tanks use this form of steering because it allows a lot of traction.
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline   Reply With Quote
Old 22nd February 2004, 02:59 PM   (permalink)
Experienced Member
Thanks for the info pike!
Andy here's a site I found that I think it's good for absolute beginners (like me)
http://www.mstracey.btinternet.co.uk...al/picmain.htm
Old 22nd February 2004, 04:40 PM   (permalink)
Experienced Member
falleafd is on a distinguished road
Send a message via Yahoo to falleafd
pike,
you got mistakes, the servo motors have two typical types which are DC servo and AC servo.
A DC motor is the most popular motor in robotic applications. Servo mechanic structure is just a DC motor and an encoder fixed together.
Servo motor is a close loop motor. You need to use PWM to drive a servo. you may use some chips like: TA7288A, L293, L293D, L298, ...
The motor you say is a Stepping (Step or Stepper) motor. Stepping is a open loop motor, the smallest full step is 0.72 deg/step. However, you may drive it at half step mode, or microstep mode to make it nearly continously run. The suitable chips for stepping may be ULN2003A, ULN2803....
http://www.cs.uiowa.edu/~jones/step
mario,
But normally, for beginner, you should try with simple DC motors.
To drive a small robot, there are many model of wheeled mobile robots. However, you can use NEWT model, which is easy to drive the robot, with 2 active wheels. Active wheels, that is, the wheels are connected to motors. An the 2 wheels are on opposite sides.
At first, you should solve the kinetics, and understand how to drive a robot. There are many simple robot projects, especially on linefollowing. However, my data was lost, and I don't remember the usefull URLs. But you may check in this forum, people discussed much bout it.
You can firstly build a line follower with basic PIC 16F84, it's very easy, and you can build your own IR sensor to detect the line. You need only 2 pins of PIC to detect IR sensor. Try it, and good luck.
falleafd is offline   Reply With Quote
Old 23rd February 2004, 06:03 AM   (permalink)
Experienced Member
my mistake....sorry.
Old 23rd February 2004, 03:01 PM   (permalink)
Experienced Member
ivancho is on a distinguished road
There are some simple fact that you need to know about motors.... There are 3 basic types of motors:
-Simple DC Motors
-Stepper Motors
-Servo Motors.
You sould research those, "simple" DC motors will run at high RPMS... that means that you are going to need to lower those RPMS to gain some torque. Torque is the force need to move somthing. So a DC motor will need some gearhead to lower the RPMS and increase the torque.... but how much torque you need depends on how heavy it is that you are trying to move. This motors have 2 wires where you connect power to, and depending on the polarity the motor moves in certain direction.
Stepper motors like mention before are motors that rotate in steps. They normally have 4 wires and can be either bi-direcetional or unipolar. Stepper motors are more difficult to "drive" out of all of the motors, mostly because it need precise stepping frequency. They also need to be ramped to speed, and the faster they go the less torque they have, and the slower they go the more torque they have.
Servo motors are DC "geared" motors with a feedback and electronics included..... These motors have 3 wires: 2 for power and a signal wire that will move the servo one direction or the other depending on the pulse width you send. The way this motors work is they move a potentiometer, each time they rotate, the electronics inside read the value of the potentiometer and see if the motor is located at the position where the siganl is commanding it to go. The siganl you send to the stepper is between 1ms and 2ms... 1.5msec being in the dead center. (Research on servo motor to make sure you understand what I mean)
Servo motors are the easiest to use, if you where to modify it for continous rotation. For U$13 you have a DC gearhad motor with some known torque and the electronics needed to drive them, all in a compact packet. And the control of thise motors is by far the quickest and simplest of all.
To turn a 'bot all you do is drive a wheel faster than the other one. The robot will tunr toward the wheel that is moving slower. IF you where to have one wheel stopped and the other running you will accomplish a 360 degree turn. That is the easies way to make a robot turn. Most of the robots will have 3 wheels one caster and the other two motorized.
Good luck
Ivancho
ivancho is offline   Reply With Quote
Old 26th December 2006, 06:57 PM   (permalink)
mr.engineering is on a distinguished road
Send a message via MSN to mr.engineering
i read all the thread...and i got that to build an easy moving robot,easy in rotating also,use servo motors is the best,right?
i have a question to ask.....do i need a motor for each wheel
if i have a 4 wheeled robot or 2 wheels,do i need a motor for each,or i can control both by one motor
thanks in advance
really great thread,i got alot out of it
If you can dream it, you can do it.
mr.engineering is offline   Reply With Quote
Old 29th December 2006, 05:13 AM   (permalink)
ElectronikCid122 will become famous soon enough
well lets say u have 2 motor s. one which will make it got forward and backwards and 1 which will make it go left and right. now to make them go forwards backwards left right the polarities of the motors switch. and im pretty sure thts done by a speed controller servos or maybe even a relay
just becaus it doesnt work, doesnt mean its not an accomplishment
ElectronikCid122 is offline   Reply With Quote
Old 8th January 2007, 04:42 PM   (permalink)
pops is on a distinguished road
Any way... how to control two motors ie varying their speed to turn left or right, opposite direction to circulating along it self...
Please give me full depth... am a NEW one...
Thanks...
pops is offline   Reply With Quote
Old 9th January 2007, 01:21 AM   (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
The most common method to control the speed of a DC motor (like RC car motors) is using an H-bridge, it's basically 4 transistors or Mosfets in an h configuration that allow controlling which leads are connected to the power or ground lines. There have been exaustive posts in the forums here and Wikipedia should have some information about them but I'm not sure as I can't access it right now. Any Google for h-bridge will give you everything from basic theory to advanced circuits.
Curiosity killed the cat; That's why they have nine lives.
Sceadwian is online now   Reply With Quote
Old 9th January 2007, 02:26 AM   (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
Best tutorial I've found on H-bridges so far:
http://www.modularcircuits.com/h-bridge_secrets1.htm
Has good diagrams and goes over the basics as well as other "little" side issues like flyback diodes, and high side. It also goes over the different kind of switching methods available.
Old 10th January 2007, 12:22 PM   (permalink)
Experienced Member
William At MyBlueRoom is on a distinguished road
I like the Tamiya gearboxes, not too hard to find and about the price of a single servo motor. The Dual Gearbox pictured below is what I'm using in my upcoming robot chassis (Mongoose)
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline   Reply With Quote
Old 3rd February 2007, 03:50 AM   (permalink)
rikaldrey is on a distinguished road
@ William At MyBlueRoom
Where did you get your tamiya gearbox? Do I need to buy a certain tamiya toy to get that gearbox or I can buy the gearbox only? Please guide me as I am a noob also.
One more thing, where can I fine servo motors? can I buy them also? Do I need an h bridge to drive a servo motor? Thanks in advance.
rikaldrey is offline   Reply With Quote
Old 1st March 2007, 06:15 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
I've found the gearboxes available at many hobby stores.
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
