Old 3rd August 2002, 04:07 AM   (permalink)
Default Robot treads
Anyone have experience with making treads (tracks) for a bot? Could you share your experience, i am looking for ideas.
thanks
int12h is offline
Old 2nd September 2002, 03:29 AM   (permalink)
hmmm...this might be useless to ask since noone responded to my original question, but...
I have treads on my robot, but they are slipping off the wheel hubs. Does anyone know of some sort of correction device that can keep the treads on the wheels?
thanks,
bd
int12h is offline
Old 2nd September 2002, 11:48 PM   (permalink)
Default tracks?
It's all physics. Question is, and always is, how big.
I will guess that you have a small bot that weighs in at less than 20lbs.
Use the thread from a mountian bike tire. Use a SHARP utility knife to seperate the side wall.
Try to use the whole tire thread so you don't have to splice. maybe you could use an idler pully to take the slack.
To keep the track on, your wheels might resemble spools.
Email pictures / specs of your bot to me. I can help you. And I full of it.
ampedtech is offline
Old 3rd March 2003, 02:43 AM   (permalink)
I have the same problem, that is, on a robot which doesn't yet exist.
I've had several suggestions from the guys at uni, the best of which seems to be to make your own with liquid rubber. molding a lip onto the edge.
Keep in mind I haven't done it yet....
Jay is offline
Old 31st May 2003, 03:32 PM   (permalink)
hi i am hassan from the uob , i wany to ask u how i can make my flame sensor more sensitive
has_abiad is offline
Old 31st May 2003, 06:11 PM   (permalink)
Soft rubber treads are hard to come by, therefore a lot of people resort to the ones used in toys that were obsoleted. www.sozbots.com has some kits available. I have heard of people using double sided timing belts for cars, but I think these are expensive.
For the connection, this can vary. Many rely on simple friction with grooves to keep it aligned. There are other systems which look like a chain and sprocket..
Steve
Scubasteve is offline
Old 16th August 2003, 05:03 PM   (permalink)
Default Try o-rings
For non-traction (pulley to other wheels) use o-rings which are easily available. For traction (tank-style) timing belts would be your best bet. 2 normal problems: belts or any other arrangement slipping off the wheels
and the wheels not being properly aligned in the same plane. Avoid these problems
abe_xabre is offline
Old 29th September 2003, 06:46 PM   (permalink)
www.smallparts.com has belts and treads which I would consider ideal for small robots. it also has the wheel hubs and gears ect.
Echelon 01 is offline
Old 8th May 2006, 05:13 PM   (permalink)
Nelwick has a full setof unusually large (though not very large) treads and sprockets.
http://nelnick.com//nelnickrobotics/...b7a9209bf769f2
There are also the tiny-sized plastic treads and sprockets that acroname and solarbotics carry. Pricey though. There is a set where the drive sprocket is made to go on servo motors, and another kind where the drive sprocket (has a different hole) to go on a specific kind of geared motor.
dknguyen is offline
Old 8th May 2006, 05:22 PM   (permalink)
How about the drive belt from a chopper?
Papabravo is offline
Old 25th May 2006, 03:51 AM   (permalink)
http://www.budgetrobotics.com/shop/?...22&cart=309543
ryanerb is offline
Old 25th May 2006, 09:00 AM   (permalink)
Thumbs down
When I saw this thread I thought it was worth looking at but after a quick scan This is another case of bringing out posts from from years ago. Well just look at some of the titles on some of the O.P's I've never seen so many Site Admin's in one post Well I don't know when this forum was made but this post started in 2002 and 4 years later the post is taken up as it was yesterday.
bryan1 is offline
Old 28th May 2006, 06:32 AM   (permalink)
In 4 years, absolutely no progress has been made on the availbility of tank treads for medium sized robots...how sad.
such is the timeless task of searching for miniature robot tank tracks...
dknguyen is offline
Old 6th November 2006, 06:12 PM   (permalink)
I haven't gotten around to doing this yet, but I'd guess it wouldn't be too tough to use roller chain and sprockets for treads, and cast rubber traction pads to attach to the chain. Roller chain is available in many sizes and styles and casting rubber is easy to find on the web.
Tracy Walker is offline
Old 7th November 2006, 12:41 AM   (permalink)
Stop touching it.
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline
Wireless robot (with a camera) bloody-orc Robotics Chat 30 2nd September 2008 11:03 PM
Robot wars!University of Cape town Mechatronics project riki4eva Electronic Projects Design/Ideas/Reviews 7 28th June 2008 05:52 AM
Motor Sizing For Moving Robots dknguyen Electronic Theory 6 25th April 2007 10:43 PM
Mobile robot convoying praetorian Robotics Chat 6 31st December 2004 11:47 AM
laser seeking robot Syntax Electronic Projects Design/Ideas/Reviews 3 13th May 2003 03:50 AM
