hi, i wanted to get a GPS module for my project. the GPS should work on 5V and i want this to be connected to a GSM via microcontroller... should give me some accuracy as i need to calculate the speed from the data received. i wanted to know which GPS module to go with as i am not used to or i cant get hand on one easily...i am planning to get it from else where so wanted some one to tell me which module to go with.. would be thankfull if someone cud help me reagrds Jijoy | |
Here is one tha I saw not too long ago... I have never used it so I can't help you with that... I just thought it was interesting http://www.acroname.com/robotics/parts/R217-TR-GPM.htmlIvancho | |
The Garmin GPS 16 is a good one, its WAAS capable(very accurate <3m) http://www.garmin.com/products/gps16/ Available here: http://www.navtechgps.com/supply/gps16.asp
__________________ Eric. | |
thnx for the reply.. i have received a Quote from u-blox regarding there GPS module model no:RCB-LJ. the details are available on www.u-blox.com. i wanted to know if anyone has got any idea about this model or if anyone can tell me from where i can get help in selecting a good GPS module for my project. atleast tell me a site or forum where i can get these info i been on the search for few weeks with no solid result expecting some help | |
What kind of "solid results" are you looking for? I typed GPS and GPS Module into google and came up with detailed info on just about every gps module made.Like I said above, one of the best(if not the best) is the Garmin GPS 16.I have also had good experiences with the Superstar GPS. http://www.navtechgps.com/supply/pri...line=superstar
| | #6 |
what i meant by solid result is i cant decide which gps to select or which will be best for my project..project funds are limited to say Rs.10,000 which include GPS and some other things...so have to limit my GPS fund to Rs.5000 i.e approx $120. another is that there arent much GPS modules available in India and after searching lot i just found one company named u-blox which provides GPS modules here. so if i have to get some other company module i will have to decide on which module to get and then ask someone to get it frm else where... i dont think garmin modules are avialable in India..there GPS units are avaialbe but not as modules if you know any comapny which has got distributirs in India whose products you can recomend pls let me know | |
| | #7 |
This was posted to the PICList the other day: http://www.codereward.org/ They're not in India but you can mail order it and it's in your price range.
__________________ If this is not what you expected, please alter your expectations. | |
| | #8 |
hi issac, thanx that was real helpfull..wanted to know somethin about the GPS module... do you know what all iformation this GPS module will give..what i wanted to know is if it can give the speed..that is does it give speed directly or do we have to calculate it.. another is how about the accuracy what is the PCB on the site used for..i dint understand it thats y.. pls reply | |
| | #9 | |
__________________ If this is not what you expected, please alter your expectations. | ||
| | #10 |
About the U-BLOX GPS's, i can say that they are the best ive worked with so far. The best TTFF, accuracy and comms. The MS1 model is a good one, with a PLCC package. asena | |
| | #11 |
Dear Jijoy We, Advanced Micronic Devices Ltd., Bangalore, supply and support Garmin, Jupiter GPS OEM modules in India. However, Garmin modules are not affordable for you since your budget is only Rs.10,000.00 We can supply Jupiter GPS module in that budget. For details contact K.M.Girish Advanced Micronic Devices Ltd. girish@amdlsed.com Ph: 080-26507800/26529692 Regards, Ravi Kiran. | |
| gps, module |
