Old 29th April 2008, 08:48 PM   #1 (permalink)
ZX3ST is on a distinguished road
Send a message via AIM to ZX3ST Send a message via Yahoo to ZX3ST
Default Velocity sensor for a car-based robot
Anyone know of a reasonably priced velocity sensor to be used on a hobby-grade R/C car?
We're trying to program the car to go specific distances, but any elevation change makes a timing structure fall apart.
I'm stumped...
ZX3ST is offline   Reply With Quote
Old 29th April 2008, 08:53 PM   #2 (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
As in measuring the number of wheel rotations? Is this an electric or nitro? If it's electric, brushed or brushless?
THe most power plant independent way of doing (best simple:reliable ratio) is to sense the number of wheel rotations and take into account the radius of the wheel and assume no slip. At the speeds and accelerations of RC cars though, no slip may not be such a valid assumption.
Disclaimer: Avatar for entertainment purposes only.
Old 29th April 2008, 09:16 PM   #3 (permalink)
It's electric, and we're running it at relatively slow speeds, so no-slip conditions would be a safe asumption.
And yes, the number of wheel rotations, or even some ratio of it would be fine.
The only velocity sensors I can find so far seem to be relatively proprietary and work only on specific robot kits offered from some hobby establishments.
Old 29th April 2008, 09:53 PM   #4 (permalink)
Experienced Member
Since the wheels on hobby grade cars are on suspension, it might not be so easy to mount something stare at the wheels and watch their rotation- dirty and dangerous for whatever is doing it. Your best bet might be to watch the motor's rotations and take into account the gearing and wheel radius. THere will be of course errors in the initial measurements of the gearing and wheel radius as well as changes in those measurements as they wear and deform. This will cause an unbounded error that will go to infinite over time swamping the actual measurements- but that's always the case when you are making relative measurements.
What does your motor look like? It probably has a tiny little shaft coming out the rear end that you could probably mount an encoder disc to, then you mount a sensor to watch it to see how fast it spins.
http://www.geology.smu.edu/~dpa-www/.../encoders.html
Or use GPS if you are outdoors +/-10m is small compared to the distance being travelled.
Car Follower/Tracker eugenesiew Electronic Projects Design/Ideas/Reviews 3 9th October 2007 02:38 PM
Final Year Project (DIPLOMA LEVEL) eugenesiew Electronic Projects Design/Ideas/Reviews 5 3rd October 2007 04:14 PM
68HC11 Based Robot Help theinfamousbob Robotics Chat 6 10th March 2007 09:07 AM
''robot based on microcontroller'' mohammed elzaq Robotics Chat 3 30th July 2005 05:14 PM
computer based robot bloody-orc Robotics Chat 1 22nd December 2004 06:13 PM
SEO by vBSEO 3.1.0 (Unregistered)
