Old 23rd April 2008, 03:04 AM   #1 (permalink)
Experienced Member
Hank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of light
Default limited R/C control of Tamiya gearbox
I'm in the process of hacking a cheap remote control and its receiver to use it for controlling a Tamiya double gearbox. I was wondering if anyone had any thoughts about what the best options for direction and steering would be?
The control was only originally designed for forward, stop (centre), and back on the left stick, and left, centre, or right on the right stick. All positions are non-analog (either full on or full off). I suppose if I hack the controller, I could also get two more control options... hmm... actually, what I have is a four-bit output, don't I? So I guess it's actually 16 different options.
It's funny how you think about these things as you write them out! Anyway, still back to the original question, and I guess supposing 16 options (including one of them being the gearbox doing nothing), what would you prefer for motion, steering in particular (turret, etc), but I suppose there could be speed options, too?
Hank Fletcher is offline   Reply With Quote
Old 23rd April 2008, 03:45 AM   #2 (permalink)
Experienced Member
Sorry: for those who don't know, this will be two, independently-powered wheels with an idle caster kind of set-up. If you had a choice of 15 movements, what would they be?
Old 23rd April 2008, 05:11 AM   #3 (permalink)
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
That sounds like an AM, 27-MHz cheapo I had 10 years ago. Basically, each stick controlled a motor -- full speed on, off, full-speed reverse. A couple of us built twin-motor, ultralight models. I think they were called Turbo Sports or something. In theory, you could fly with both sticks forward and turn with differential power. Our record flight, with some semblance of control, was maybe 100 yards. In other words, it was damn hard to do.
I mention that episode, because if you have two wheels, each full forward, stop, or reverse, you are going to spend most of the time going like an arrow or spinning.
My advice: buy a used proportional receiver and transmitter. Try the modeler flea markets. My guess is that some guy would be happy to get $25 for a 4 channel TX and RX. I gave all of mine away to kids just starting out. Most of the guys I fly with have done the same with old equipment.
Good luck. If you do try to make the robot with what you have, please post some clips of it in action.
John
jpanhalt is online now   Reply With Quote
Old 23rd April 2008, 05:17 AM   #4 (permalink)
3v0
Moderator
3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all
I agree with John about getting a better rig but.
If you are willing to hack the box you could do most anything you wanted with a pair of uC to encode/decode the stream.
To control the world from your PC with USB I suggest USB Bit Wacker
3v0's Tutorials for ABSOLUTE BEGINNER
C, PIC 18F, MPLABŪ and MCC18 Compiler
3v0 is online now   Reply With Quote
Old 23rd April 2008, 06:09 AM   #5 (permalink)
Experienced Member
nickelflippr will become famous soon enough
One suggestion might be to decode the receiver input with a microcontroller, then redirect your outputs to mimic tank control. Meaning the right and left sticks would control their respective motors forward, off, back. That way just seems more intuitive to me.
With those motors, speed control may be more hassle/cost than its worth. The motors need to be geared fairly low to get the platform moving.
nickelflippr is offline   Reply With Quote
Old 23rd April 2008, 06:14 AM   #6 (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
With 4 bits you can have 2 bits per side which will give you 2 forward speeds and 1 reverse per side (+stop).
Pommie is online now   Reply With Quote
Old 23rd April 2008, 08:02 AM   #7 (permalink)
Experienced Member
Torben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of light
I know I'm missing something here, but it seems to me that with 4 bits you have 16 options: stop and reverse plus 6 speeds per side. If you split the 4 bits into 2 2-bit chunks you only get stop and reverse plus 2 speeds per side.
Mind you, I do have a couple of beers in me.
Torben
Torben is offline   Reply With Quote
Old 23rd April 2008, 08:10 AM   #8 (permalink)
Experienced Member
Torben
You need to turn. Fast forward right and slow forward left gives a fast moving turn to the left. The different combinations give you different speed and turn rates.
Edit, I see the confusion now. Stop, reverse and 6 speeds per side requires 8 combinations which is 3 bits per side. You can't split 16 combinations into 2 lots of 8. You can do 8 combinations plus 2 combinations.
Old 23rd April 2008, 12:53 PM   #9 (permalink)
Experienced Member
I think 3v0 clued into what I'm thinking about doing, although I'll probably just use one mcu on the receiver side to collect the 4-bits (so no streaming for the first crack at this, although that'd definitely give me more options!). Presuming the 4-bits can be processed, that gives 15 movement options other than full-stop (0), with the bits being interpreted for whatever other options are most desirable.
Do we all agree, though, that even given the extra resources and more often than not redundancy, that we'd prefer to have symmetrical options with respect to both wheels? I just remember being really irritated as a kid with those R/C cars that could turn left or right when moving forward, but only turned in one direction when backing up. If real life were like that, I'd never be able to parallel park!
Old 23rd April 2008, 01:23 PM   #10 (permalink)
Experienced Member
Motion options (and what each wheel is doing):
0 - stop
1 - forward, top speed (fast left, fast right)
2 - reverse, top speed (fast reverse left, fast reverse right)
3 - ccw fast (fast reverse left, fast right)
4 - cw fast (fast left, fast reverse right)
5 - foward, slow (slow left, slow right)
6 - reverse, slow (slow reverse left, slow reverse right)
7 - ccw slow (slow reverse left, slow right)
8 - cw slow (slow left, slow reverse right)
9 - right turn (slow left)
10 - left turn (slow right)
11 - right bend (fast left, slow right)
12 - left bend (slow left, fast right)
13 - right reverse bend (fast reverse left, slow reverse right)
14 - left reverse bend (slow reverse left, fast reverse right)
15 - fire!
Opinions?
Old 23rd April 2008, 01:29 PM   #11 (permalink)
3v0
Moderator
How are you going to retrofit the joysticks?
Old 23rd April 2008, 02:09 PM   #12 (permalink)
Experienced Member
I was thinking of hooking up the controller to my parallel port, so presuming I can handle the cpu programming, the options for controlling the robot would be the usual ones associated with a computer: keyboard and mouse (hmm... maybe a game controller, too?...)
Old school!
Old 23rd April 2008, 02:13 PM   #13 (permalink)
3v0
Moderator
It looks like you are going to have processing on both ends. You may as well use one or more channels to send digital data that you can decode.
About the only thing you are missing is data definition / protocol.
Old 23rd April 2008, 04:36 PM   #14 (permalink)
Experienced Member
Edit, I see the confusion now. Stop, reverse and 6 speeds per side requires 8 combinations which is 3 bits per side. <b>You can't split 16 combinations into 2 lots of 8.</b> You can do 8 combinations plus 2 combinations.
That's what I mean by "splitting the 4 bits into 2 per side". You then have 2^2 = 4 discrete options per side, which as you say is quite limiting.
If you instead use your 4 bits together as one 4-bit value and decode it on the bot then you have 2^4 = 16 different options. Use 8 for one side and 8 for the other.
Hank wrote out one list of options. My first idea was slightly different:
0000 Left Stop
0001 Left 1
0010 Left 2
0011 Left 3
0100 Left 4
0101 Left 5
0110 Left 6
0111 Left Reverse
1000 Right Stop
1001 Right 1
1010 Right 2
1011 Right 3
1100 Right 4
1101 Right 5
1110 Right 6
1111 Right Reverse
. . .but generally the same kind of idea.
Torben
Old 23rd April 2008, 06:28 PM   #15 (permalink)
Experienced Member
Seems to be getting a bit convoluted. With one of those cheap Vex controllers that have been talked about, you hold the processing to the receiving end. I am sure that having computer control could have some advantages tho, like maybe not having to recharge transmitter batteries?
FC-130: pimping the Tamiya gearbox? Hank Fletcher Robotics Chat 25 15th April 2008 09:24 PM
tamiya gearbox comparison? Hank Fletcher Robotics Chat 12 17th February 2008 03:49 AM
Using Oscilloscopes mechie Electronic Theory 9 29th November 2007 09:49 PM
Tamiya Gearbox bushings. 3v0 Robotics Chat 2 22nd September 2007 10:17 PM
Central Heat and Air Remote Control ae4jm General Electronics Chat 4 6th June 2006 12:08 PM
