Old 21st April 2008, 02:44 AM   #1 (permalink)
sckooi is on a distinguished road
Default speed control...
hi all,
You think i possible do the line follower robot with speed control??? Robot will run faster when detect the black line. and run slower when detect the blue line. Please give any advice.. Thanks
sckooi is offline   Reply With Quote
Old 21st April 2008, 03:08 AM   #2 (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
Originally Posted by sckooi
hi all,
It is possible. YOu will need fancier sensors than normal to tell the difference between a black and blue line.
Disclaimer: Avatar for entertainment purposes only.
dknguyen is online now   Reply With Quote
Old 21st April 2008, 12:14 PM   #3 (permalink)
So normal IR sensor can differancial black and blue colour???
If cannot. Any recommand??? Because colour sensor is too expensive.
Old 22nd April 2008, 07:11 AM   #4 (permalink)
vdd
Experienced Member
vdd is just really nicevdd is just really nicevdd is just really nice
May be you can use LDR. It can not detect different colour but different colour may reflect different amount of light. So different voltage will be obtained by the LDR.
vdd is offline   Reply With Quote
Old 22nd April 2008, 03:56 PM   #5 (permalink)
mudassir_semiconductor is on a distinguished road
if ur using microcontroller ..... tkae one 555 timer to generate pulse from ldr. calculate the time of pulse r number of pulse according to ur ckt desing .
then according to the range
mudassir_semiconductor is offline   Reply With Quote
Old 22nd April 2008, 04:52 PM   #6 (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
A CDS cell cannot differentiate between colors, but only change the amount of resistance. A CDS cell cannot differentate between what is a black, blue or green.
Just throwing that out there.
Visit my website!
http://www.freewebs.com/electronic-hobbyist
Krumlink is online now   Reply With Quote
Old 22nd April 2008, 05:45 PM   #7 (permalink)
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
Light detectors simply give intensity information. If you want color information you either need a detector that doesn't respond to certain wavelengths, or you need to use filters for the various wavelengths. The latter method is by far the most commonly used method. (I consider a photodetector with a built-in filter or monochromator as the latter, not former type. The former type might be represented by the cones in the retina.)
That being the case, you could consider a line follower that had two detectors. One detector would have a filter that allowed max. transmission for one color of interest and the other other would have a filter for the other color of interest. Knowing the ratio of the outputs for color 1
and for color 2 would allow you to determine which line the detector was "seeing."
From a construction standpoint, I would use fixed detectors and filters rather than one detector with movable filters, but either way will work. John
Edit: This may be a bit arcane, but I used the cones as an example of a wavelength selective detector, not filter based detector, because of the very close, molecular association of the protein opsin with the actual signal generator (See: http://en.wikipedia.org/wiki/Rhodopsin).
A better example might be the photoelectric effect one sees with LEDs in which the color sensitivity is due to the doping (See:http://scitation.aip.org/getabs/serv...cvips&gifs=yes
http://scitation.aip.org/getabs/serv...cvips&gifs=yes).
jpanhalt is offline   Reply With Quote
speed control of AC motors hamid Datasheet/Parts Requests 5 17th June 2007 03:08 PM
Intelligent digital speed control system for small truck model classic Robotics Chat 2 8th October 2006 11:57 AM
Government Ignores Police Concerns In Changing Speed Limit Rules ThermalRunaway Chit-Chat 5 20th August 2006 02:35 AM
speed control of dc motor itsmyturn General Electronics Chat 2 24th March 2005 12:39 PM
design problem faced on PWM brushless motor speed control swear_swear Electronic Projects Design/Ideas/Reviews 0 23rd June 2003 01:06 AM
