| New Member | Hello, I've been working on a few ideas on a Indoor Position System. I am still in the reasearch phase of my Masters. Whilst I know my idea is not novel, I still wish to presue my IPS which is based on angles not distances. Can someone please point me in the right direction for RF based beacons and communcaition. My idea is simple, but is based on the robot being able to search for a beacon, and once found stop so that the robot is facing that one particular beacon. Is there such a thing as a mono-directional rf antenna or locating system? If so can you offer me some help? Cheers K |
| Super Moderator | Quote:
| Moderator | I was thinking of attaching a SHARP IR detector to a servo, and have it scan the room until it picks up something moving. Just a idea.
__________________ MechTronics |
| Moderator | You can use the analog versions of them and a ADC to select what values to react upon
| Moderator |
| Moderator | You could use 2 of them (far range and close range) or ultrasound sensors (bit more expensive)
| New Member | Thats exactly what I wanted to know. Thanks for your help Nigel Goodwin. The trouble with the IR Rangers is that line of sight is required. I did not mention it in my first post, but the system cannot be line-of-sight. Mainly because if the robot is in an office or something, a person, computer, or some object may block the path to the beacon. Rf is the solution as long as I get a fairly decent transmitter. Cheers |
| Experienced Member | Quote:
From the 1960's to about the present, aircraft navigated by an OMNI system. Older systems (NDB, non-directional beacon and AN) were also used. And of course, GPS is replacing Omni. The Omni system allows one to determine position (azimuth from the transmitter) by determining a phase shift of the transmitted signal (AN used Morse code). John Edit: Here's a reference for omni (VOR):http://en.wikipedia.org/wiki/VHF_omnidirectional_range Corrected technical aspect of the NDB and AN systems. Last edited by jpanhalt; 16th April 2008 at 02:35 AM. | |
| Motion Capture System | nilu_2005 | Electronic Projects Design/Ideas/Reviews | 3 | 30th April 2007 01:34 PM |
| Electronic system to stop sleeping problems - help with design of system | ZackSmith | Electronic Projects Design/Ideas/Reviews | 1 | 29th October 2006 09:42 AM |
| Car battery charging system | Barwick | Electronic Projects Design/Ideas/Reviews | 1 | 17th June 2006 11:48 AM |
| Consulting on Switch system. | GOMBO | General Electronics Chat | 1 | 26th September 2004 09:27 AM |
| i need a schematic of pic based alarm system..help me please | BurhanUnalmis | Electronic Projects Design/Ideas/Reviews | 0 | 26th April 2003 02:42 PM |
