Experienced Member
You came to the same conclusion I had: that it might be easy enough to modify the gearboxes to accommodate motors of slightly different shapes. Ideally, I thought I'd see if I could find any other motors that were as close to exact as possible. I still say the 4.5V nominal rated FC-130 would be a better product for Tamiya to use, but maybe it wasn't in production when they first developed their various gearboxes? Let me know how easy you think some modification will be once you get your gearbox. Making sure the shaft is where it ought to be seems like the biggest challenge. I can see some leeway with gearbox models with plastic frames, but the one I'm most interested in modding now is the universal gearbox, which has a metal frame. Last edited by Hank Fletcher; 14th April 2008 at 06:59 PM. |
Experienced Member
Experienced Member
Moderator
The SN754410 powers the motor from VCC2. If you want to run them at less then 5 volts you could lower the voltage. The datasheet says it will work between −0.5 V to 36 V.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
Experienced Member
Tamiya also makes some HE gearboxes with more torque and bigger motors.
Experienced Member
Right, my gearbox arrived today. A few observations;
It's a very fast gearbox, I've built it in the lowest ratio configuration. Without PWM this will be more than sufficient. PWM would allow the next ratio to be used, I think the top two will be useless for robotics. The gearbox is a strong unit, so it should be able to take a more powerful motor. Now the good bit, if you were to remove everything to the left of the red line in my attachment you would be left with a flat bulkhead with holes in it. This would be easy to adapt to take a larger motor (with bracket and suitable gear). Having said this, the gearbox and motor combo is already impressively fast and powerful. |
Experienced Member
Problem might be the motors are side by side, only a slight space exists between them. A larger diameter motor won't work.
Experienced Member
I think if you moved the spur gear to the middle of it's shaft, you could fit slightly larger motors. Or you could use the single motor version, or just use a larger motor and different gearbox (probably the best option!)
Experienced Member
Those little gearboxes have plenty of torque at 114:1 or higher, what sort of load are you trying to move.
The little brass bearing won't hold out for big loads, you'd realistically need ball bearings. |
Experienced Member
It's hank who wants to mod them, to take a higher voltage motor from what I can tell. I just thought it was fun to have a nosy at the gearboxes to see what could be done!
Experienced Member
| tamiya gearbox comparison? | Hank Fletcher | Robotics Chat | 12 | 17th February 2008 03:49 AM |
| tamiya gearbox using solar panels? | Hank Fletcher | Robotics Chat | 13 | 14th February 2008 05:15 PM |
| Tamiya Gearbox bushings. | 3v0 | Robotics Chat | 2 | 22nd September 2007 10:16 PM |
| Opto sensors on a geartrain (Tamiya Double Gearbox) | blueroomelectronics | Robotics Chat | 29 | 20th March 2007 10:07 PM |
