Old 14th April 2008, 03:09 PM   (permalink)
Experienced Member
Hank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of light
I would just like to thank whoever negative repped me for the above post. Yes, perhaps it wasn't wonderfully helpful, but I did make a suggestion, and it wasn't "can Haz help plz?"
Perhaps whoever it was would like to justify it?
For the record, it wasn't me!
You came to the same conclusion I had: that it might be easy enough to modify the gearboxes to accommodate motors of slightly different shapes. Ideally, I thought I'd see if I could find any other motors that were as close to exact as possible. I still say the 4.5V nominal rated FC-130 would be a better product for Tamiya to use, but maybe it wasn't in production when they first developed their various gearboxes?
Let me know how easy you think some modification will be once you get your gearbox. Making sure the shaft is where it ought to be seems like the biggest challenge. I can see some leeway with gearbox models with plastic frames, but the one I'm most interested in modding now is the universal gearbox, which has a metal frame.
Hank Fletcher is offline   Reply With Quote
Old 14th April 2008, 03:44 PM   (permalink)
Experienced Member
zanes has a spectacular aura about
Ah! I thought you meant the plastic ones, I'm getting the double gearbox. Looking at photos of the universal one, I think it would be possible to modify it as well, a motor bracket would need to be made though. Is it more power you're after, or higher voltage tolerance?
zanes is offline   Reply With Quote
Old 14th April 2008, 07:08 PM   (permalink)
Experienced Member
I thought it'd be fun to see if I could put a bit more power through the gearboxes, but now knowing what I know about the FC-130, and it being essentially dimension-perfect to the FA-130, I just wish the FC-130 came stock with the Tamiya gearboxes instead. I guess my main criteria for that desire is that the FC-130 seems better suited to the specs for the above mentioned h-bridge IC (more appropriate voltage and current ranges with the FC-130), so it's mainly a convenience-of-compatibility issue.
Old 14th April 2008, 07:46 PM   (permalink)
3v0
Moderator
3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold
The SN754410 powers the motor from VCC2. If you want to run them at less then 5 volts you could lower the voltage. The datasheet says it will work between −0.5 V to 36 V.
search engine for electronic parts
Junebug USB PIC programmer kit. USB Bit Wacker
3v0 is online now   Reply With Quote
Old 14th April 2008, 08:53 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Tamiya also makes some HE gearboxes with more torque and bigger motors.
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 15th April 2008, 06:50 PM   (permalink)
Experienced Member
Right, my gearbox arrived today. A few observations;
It's a very fast gearbox, I've built it in the lowest ratio configuration. Without PWM this will be more than sufficient. PWM would allow the next ratio to be used, I think the top two will be useless for robotics.
The gearbox is a strong unit, so it should be able to take a more powerful motor.
Now the good bit, if you were to remove everything to the left of the red line in my attachment you would be left with a flat bulkhead with holes in it. This would be easy to adapt to take a larger motor (with bracket and suitable gear).
Having said this, the gearbox and motor combo is already impressively fast and powerful.
Old 15th April 2008, 06:58 PM   (permalink)
Experienced Member
Problem might be the motors are side by side, only a slight space exists between them. A larger diameter motor won't work.
Bill
Old 15th April 2008, 07:02 PM   (permalink)
Experienced Member
I think if you moved the spur gear to the middle of it's shaft, you could fit slightly larger motors. Or you could use the single motor version, or just use a larger motor and different gearbox (probably the best option!)
Old 15th April 2008, 07:06 PM   (permalink)
Experienced Member
Those little gearboxes have plenty of torque at 114:1 or higher, what sort of load are you trying to move.
The little brass bearing won't hold out for big loads, you'd realistically need ball bearings.
Bill
Old 15th April 2008, 07:07 PM   (permalink)
Experienced Member
It's hank who wants to mod them, to take a higher voltage motor from what I can tell. I just thought it was fun to have a nosy at the gearboxes to see what could be done!
Old 15th April 2008, 09:23 PM   (permalink)
Experienced Member
I'd thought about that for the universal gearbox, which has up to about 700:1 gear ratio. Observing the small robot arm models they have at the local community college, I noticed that the servo-driven joints have additional structure axles. What I mean is, the servo horn is connected to the joint, but the design allows for radial movement of the joined parts by the servo, but there is no force perpendicular to the servo shaft on the servo shaft. Instead, there's another part that takes the perpendicular-force load. I can remember how that did that on the opposite end of the servo horn, but I'm a little fuzzy at how they went about it at the business end - I'd have to see it again. Definitely a bushing not a bearing solution, but then they were small robots made of fairly robust metal (aluminum?).
tamiya gearbox comparison? Hank Fletcher Robotics Chat 12 17th February 2008 03:49 AM
tamiya gearbox using solar panels? Hank Fletcher Robotics Chat 13 14th February 2008 05:15 PM
Tamiya Gearbox bushings. 3v0 Robotics Chat 2 22nd September 2007 10:16 PM
Opto sensors on a geartrain (Tamiya Double Gearbox) blueroomelectronics Robotics Chat 29 20th March 2007 10:07 PM
