Old 14th April 2008, 07:31 AM   (permalink)
Experienced Member
desijays is on a distinguished road
Originally Posted by petrv
Hard to say what is your problem with the L298 PWM and H-bridge without seeing the schematics, maybe you can post it, the code can help as well. By the way, be sure not to leave out the protection diodes.
Petr
I will post pictures of the setup Im using. I believe that will help.
This is the H-bridge and motor connected.
The following picture is a picture of the entire setup Im using now, just for figuring out PWM. It has the h-bridge, power supply and the step down transformer for reducing the voltage from the wall outlet which is at 240 volts .
Now as I said before the motor in the first picture is the one causing problems. i don't know if there could be a problem with the power supply or the H-bridge. It does not run during the duty cycle. But if I hold my hands to the terminal of the motor it runs during the duty cycle. Otherwise it just gives of vibrations during the duty cycle; however long that maybe. I used a 1 second period cycle and 50% duty cycle in my first try.
And is there any standard period cycle that should be used? Because a period cycle in milliseconds for LED's is too large and a period cycle in microseconds for motors it too short... I hope Im clear!!
A scientist trys to see the world the way it is
An enginneer trys to see a world that has never been
desijays is offline   Reply With Quote
Old 16th April 2008, 07:45 AM   (permalink)
Experienced Member
Well, I asked around and finally realized what the problem was. Even though the H-bridge was grounded from the power supply, I completely forgot to ground the circuit that housed the controller that was sending control signals to the h-bridge. I did that and now it works well. It seems very simple now that I know what the problem was.
Than you
controlling fan motors using pic16f84a farasue Electronic Projects Design/Ideas/Reviews 2 4th March 2008 02:36 PM
Controlling Switches and Motors via Parallel Port JobbinJP General Electronics Chat 37 16th March 2007 05:50 PM
PIC16F627 - controlling motors drage Micro Controllers 8 22nd October 2006 11:39 AM
controlling hard disk motors using lpt kariem2k General Electronics Chat 2 14th December 2003 08:56 AM
Qbasic program for controlling stepper motors I wrote one ElectroGeek_87 General Electronics Chat 1 5th October 2003 05:19 AM
