Old 6th April 2008, 01:54 PM   (permalink)
Experienced Member
mashersmasher will become famous soon enough
Default problems with H bridge
so i thought about rigging some transistors to control some motors (which is apparently an H bridge) but any transistors i can find have so much resistance that a 250w computer power supply (for testing) has trouble lighting an led let allone a motor or even a relay. the number on the transistors i'm using are 2n 3906-338 and the motors are 2 that i pulled from a smashed up roomba i found in the trash (no battery though )
mashersmasher is offline   Reply With Quote
Old 6th April 2008, 02:05 PM   (permalink)
NightFalcon90909 has a spectacular aura about
250 watt?!
Optimally, get a few double AA batteries and some 2N2222's... together the whole deal might cost you three dollars or so... then try that and see how you go. Make sure you use the right transistors in the right places- NPN are not the same as PNP!
If it is broken, let's fix it.
If it is working, let's make it better.
NightFalcon90909 is offline   Reply With Quote
Old 6th April 2008, 02:12 PM   (permalink)
Experienced Member
ya it's an old 250w pc power supply and i'm using the 5v rail. so you think the transistors are the main problem? i admittedly only went to radio shack for components. even when i power them from a pin on my basic stamp (<6v and almost no current) it does the same thing. i power the motors from the power supply directly.
Old 8th April 2008, 03:47 PM   (permalink)
I can't really imagine that it could be anything else. If you have the transistors all hooked up correctly, then they must be blown.
A watt is power which Volt time Amps- so if you have 5 volts, that is like 50 amps... your transistors are most likely rated for a few milliamps!
Old 8th April 2008, 06:12 PM   (permalink)
Experienced Member
hmm that's definitely a possibility. i heard one hiss and pop but i removed it. the others ran pretty hot but i figured as long as they do there job then the heat was not a concern. well i guess that's what i get for buying radio shack grab bags. i tried using a voltage regulator on the 12 v rail but same thing so i guess they are toast. thanks for the input! i might use one transistor to triger some high voltage relays that i have somewhere
Old 8th April 2008, 06:17 PM   (permalink)
3v0
Moderator
3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold
You need to post the schematic.
search engine for electronic parts
Junebug USB PIC programmer kit. USB Bit Wacker
3v0 is online now   Reply With Quote
Old 8th April 2008, 06:32 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
Why didn't you look at the max allowed current of only 200ma for the 2N3906. Then look at the max current (when it starts and when it stalls) for the motor.
If you don't know what is the max current of the motor then measure its resistance and calculate the current.
Attach your schematic. Maybe the motor's current is low enough but the base current for the transistor is too low.
Old 8th April 2008, 09:17 PM   (permalink)
Experienced Member
uhh i don't have a schematic. i basically just brainstormed the idea then put it together and hoped it would work ( it is wired correctly. i checked multiple times). a knowledgeable friend described it as an H bridge and after looking it up it appears to be exactly what it is. here is a schematic i got off the web just now
http://faq.solarbotics.net/images/H2-bridge.gif
Old 8th April 2008, 11:27 PM   (permalink)
Experienced Member
The circuit from the web uses transistors rated at 800mA and a motor that has a stalled current of 360mA. it uses NPN and PNP transistors.
You are using transistors rated at only 200mA and you don't know the stalled current of your motor. You mentioned using only 2N3906 transistors, no NPN transistors, so you circuit is completely different.
Did you look up the pins on the transistors so they are not connected backwards?
Old 9th April 2008, 05:52 AM   (permalink)
Experienced Member
zanes has a spectacular aura about
And, that schematic is excellent when built with BC's.
zanes is offline   Reply With Quote
Old 9th April 2008, 10:16 AM   (permalink)
Experienced Member
crust has a spectacular aura about
You are probably not supplying enough base current to get the collector / emitter current high enough. The other option is just use mosfets. There are literally hundreds of designs on the web and even on this site that show how to build a very reliable h-bridge with mosfets. The nice thing about them is that they have a built in body diode, so you don't have to worry (on small motors anyway) about inductive spikes destroying them and their on resistance is ridiculously low so you don't even have to worry about heating them up.
Having said that, the 3906 is probably too small to drive any motor without blowing up. The smallest I have ever used is a TIP31 which is in a TO220 and it was toasty even with a small motor and no load on it.
crust is offline   Reply With Quote
Old 9th April 2008, 02:04 PM   (permalink)
Experienced Member
thanks for the help! i think i'm going to rip up some dying servos and use their controllers in the mean time while i get some better parts.
Old 11th April 2008, 05:49 AM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Old (RC) servo motors can use as much as 1 ampere.
mneary is online now   Reply With Quote
Old 11th April 2008, 10:21 AM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
1 ampere? Mine at 5V (standard size) take up about 100ma.
MechTronics
Krumlink is offline   Reply With Quote
Old 11th April 2008, 12:10 PM   (permalink)
Experienced Member
well they arn't really "old". the motors are fubar but the boards are working alright.
MOSFET For H Bridge Ayne General Electronics Chat 1 16th February 2007 12:08 AM
USB to Serial problems spondootre Micro Controllers 12 28th November 2006 08:09 AM
Need Help on High Current H Bridge pidot Robotics Chat 16 15th September 2005 06:46 AM
Bridge Rectifier Current Rating -- How much is enough? hamfiles General Electronics Chat 6 6th August 2003 06:15 AM
Wireless network bridge monitoring circuit...need pointers. Goose Electronic Projects Design/Ideas/Reviews 0 17th February 2003 02:02 PM
