| Experienced Member | Hi, im having lets say two motors which have the same RPM but operation at different voltages , one is 12V and the other is 6V , i wanna make both move in straight line which means , both have the same speed .. how do i do that ? and how PID control can help in that ? i've two encoders attached to the motors ... that's what in my pocket right now .. |
| Super Moderator | As you have encoders on each wheel, you just need to ensure that both wheels move at identical speeds and for identical distances. I don't see as PID is anything to do with it?. |
| Experienced Member | yea , but how to do that , by measuring both RPMs ? and make both RPMs the same or what ? |
| Experienced Member | Quote:
| Experienced Member | yea, i want the 12V motor to be like the 6V motor , to let the robot move at straight line path ! is that possible ? also is there faster way to do that ? because measuring RPM needs measuring the revoultion per minute ! and its not possible , i want the robot to move at straight line since its start up .. |
| Super Moderator | Quote:
| Experienced Member | Well, anyway nigel , im simulating this task in proteus , and i assume that im using 300CPP encoder with 110 rpm motors .. so how do i measure the time between pulses ? you mean Ton ? |
You should be able to use the CPP module to do this in hardware, or use software to do it. | |
| DC motor controller | rogerdodger | Electronic Projects Design/Ideas/Reviews | 12 | 2nd March 2008 11:30 PM |
| dc motor controller using microcontroller | norms09 | Micro Controllers | 3 | 5th December 2007 04:28 AM |
| closed loop DC motor control | vuchris | Electronic Projects Design/Ideas/Reviews | 0 | 30th September 2007 11:27 AM |
| Xbox 360 Tilt Controller | adamthole | Electronic Projects Design/Ideas/Reviews | 0 | 20th January 2007 05:24 PM |
| Help With Temperature Controller | bryan | Electronic Projects Design/Ideas/Reviews | 4 | 30th June 2003 12:18 PM |
