Experienced Member
Hi, im having lets say two motors which have the same RPM but operation at different voltages , one is 12V and the other is 6V , i wanna make both move in straight line which means , both have the same speed .. how do i do that ? and how PID control can help in that ? i've two encoders attached to the motors ... that's what in my pocket right now ..
Super Moderator
As you have encoders on each wheel, you just need to ensure that both wheels move at identical speeds and for identical distances.
I don't see as PID is anything to do with it?. |
Experienced Member
yea , but how to do that , by measuring both RPMs ? and make both RPMs the same or what ?
Experienced Member
Experienced Member
yea, i want the 12V motor to be like the 6V motor , to let the robot move at straight line path !
is that possible ? also is there faster way to do that ? because measuring RPM needs measuring the revoultion per minute ! and its not possible , i want the robot to move at straight line since its start up .. |
Super Moderator
Experienced Member
Well, anyway nigel , im simulating this task in proteus , and i assume that im using 300CPP encoder with 110 rpm motors ..
so how do i measure the time between pulses ? you mean Ton ? |
Super Moderator
You should be able to use the CPP module to do this in hardware, or use software to do it. |
| DC motor controller | rogerdodger | Electronic Projects Design/Ideas/Reviews | 12 | 2nd March 2008 11:30 PM |
| dc motor controller using microcontroller | norms09 | Micro Controllers | 3 | 5th December 2007 04:28 AM |
| closed loop DC motor control | vuchris | Electronic Projects Design/Ideas/Reviews | 0 | 30th September 2007 11:27 AM |
| Xbox 360 Tilt Controller | adamthole | Electronic Projects Design/Ideas/Reviews | 0 | 20th January 2007 05:24 PM |
| Help With Temperature Controller | bryan | Electronic Projects Design/Ideas/Reviews | 4 | 30th June 2003 12:18 PM |
