| Experienced Member | Hello everyone, Am sorry about this being a repost. But I was told that regarding the following topic posting in this section would elicit better responses. I would like to design and build a self balancing robot something along the lines of "Botka - The barely standing robot". Please visit the following link. http://www.revver.com/video/443032/b...tanding-robot/ It will help to understand what Im talking about. I would also like to know the areas in which I might encounter any difficulties while designing the robot. A brief description of how to make it work will also be helpful. I came across a bot by the name nBOT that is similar to Botka. And the designer of nBOT gave a vague and brief description of how it works on his website. The website in question is www.geology.smu.edu/~dpa-www/robo/nbot/ Although I read through most of the site, I could only understand like 40% to 50% of it. It would be helpful if someone could fill in the gap in simple language or lend their own insight as to how such a thing might be built. Thank you
__________________ A scientist trys to see the world the way it is An enginneer trys to see a world that has never been |
| Experienced Member | I can't remember off-hand, but I know I've seen gyro-chips for sale on the web (maybe Acroname, but I'm sure you could find them at various other locations). Use the gyro to determine the orientation of the robot (i.e. how much it's leaning over), and to power the motors proportionally. The proportional power adjustment can be heard from the motors suddenly moving quite quickly when the user knocks the robot over quickly in the video. The trick seems to be to have the wheels constantly powered in the direction the robot is falling. Another way to think about this is to compare the robot to a drag racing car. As a drag racer accelerates, the body of the car "pops-a-wheelie," moving upwards and back over the axis of the spinning back wheels. The only difference with the robot is that when it's knocked over, it continues to accelerate past the point of perpendicular. At that point, the robot quickly changes the direction of the wheels to compensate in the other direction. The effect is a robot that goes spastic when it's knocked over (on four wheels), but settles down once the feedback control realizes the perpendicular orientation. An important aspect of the design of this robot is to ensure that the motors can provide enough torque and acceleration to rotate the entire body of the robot around the powered wheels should the robot become parallel to the ground. Last edited by Hank Fletcher; 3rd April 2008 at 04:46 AM. |
| Experienced Member | Here's a gyro sensor along the lines I mentioned earlier: http://www.acroname.com/robotics/parts/R40-PG2033.html I also saw that Sparkfun had a dual-axis sensor for about the same price. With dual-axis, you could even make your robot a unicycle type! Come to think of it, if you want to get up-close-and-personal with the control process of your robot, you might try your hand at riding a unicycle yourself (warning: it's hard, especially on your balls). Either that, or buy a Segue. |
| Experienced Member | Using a gyro would be an option, but I believe the self balancing act can be achieved by using a simple distance measuring sensor as well. The following link will clarify what I am talking about... http://www.electro-tech-online.com/r...ing-robot.html I am not well aware of the advantage of using a gyro as opposed to using a 'distance measuring sensor' to achieve the self balancing act. If such knowledge is trivial please pardon my ignorance. I do know one thing with a fair amount of certainty. And that is, whether a gyro is used or a 'distance measuring sensor' is used, the program logic that eventually drives the two motors to achieve upright stability will be almost similar. If a gyro is being used then the tilt and inclination of the 'self balancing contraption' is used as input to calculate the compensation, the motors need to produce. Likewise, if a 'distance measuring sensor' is used then the distance from the ground will be used as input to calculate the compensation of the motors as in the case of the robot mentioned in the link above. The challenge arises in trying to determine an exact algorithm that will measure the distance from the surface (if 'distance measuring sensor' is used) and control the motors accordingly. Needless to say, the algorithm must be pretty quick. I was just wondering if such data is acquired only by trial and error or is there some mathematical formula that can be used to plug in the distance as input (obtained from 'distance measuring sensor') and obtain as output the speed the motors must possess to avoid toppling over? I hope I haven't crammed too much into one single post.
__________________ A scientist trys to see the world the way it is An enginneer trys to see a world that has never been Last edited by desijays; 3rd April 2008 at 10:39 AM. |
| Experienced Member | |
| Experienced Member | Do what Pommie suggests. What you can read about PID, I should add, can be "too much information," if you know what I mean. By the time you have this all figured out, you'll be amazed at how simple it all seems then. You might try developing a flow chart to help you organize your thoughts about what your robot will be doing at any given time, and how it will correct for error. In your last post, you've neglected a detail that I no doubt expect is still important to you. If, for instance, your robot is remote controlled, you'll want to make sure that your control takes into account not just the immediate status of the robot and the necessary compensation for error, but also how to factor whatever the person remotely controlling the robot is trying to effect as the desirable action e.g. the robot is rolled along a path and hits an object, and it starts to fall so it begins to compensate, and at the same time the user sends a message directing the robot in another direction. What should happen? By the way, the optical sensor robot seems to be using one of the Sharp IR sensors. You should know that these sensors only read at about 20Hz. Also, their output is non-linear, which could complicate things when calculating around the axis of the robot. And you'd need two optical sensors to do the job of one gyro sensor if you wanted your robot to balance on either set of wheels as in the video you've posted. Given the marginally greater expense but much greater precision and ease of use of the gyro sensor, I highly recommend you take that path instead. The Sharp sensors are great for what they are, but the gyro sensors are specifically designed for this type of purpose, albeit balancing R/C helicopters. |
| Experienced Member | Quote:
__________________ A scientist trys to see the world the way it is An enginneer trys to see a world that has never been | |
| | (permalink) | ||
But none the less, you have a point. I'll look into it.
__________________ A scientist trys to see the world the way it is An enginneer trys to see a world that has never been | ||
| Experienced Member | Seems like you're all set to make this project happen. As I said, I think you'll find working out the various issues actually quite trivial in retrospect (that is, after you've finished the project), and even to be enjoyable problems to resolve during the design process. Best of luck to you! p.s.: I think I can speak for forum users when I say we're always interested in the final product, and even the process, of individual projects. Feel most welcome to post your progress! |
| Experienced Member | I would like to think that this is just the beginning and Im sure of making this thing work. Maybe Im kidding myself when I say I'll do it without realizing the difficulties involved. But thats why I think sometimes ignorance is bliss. I just hope to get far enough into the project so that at that point backing out becomes a worthless option. Ill post my progress. I need to. Cos Im sure I'll need some help along the way Thanks for the encouragement hank.
| Robot wars!University of Cape town Mechatronics project | riki4eva | Electronic Projects Design/Ideas/Reviews | 7 | 28th June 2008 05:52 AM |
| New UK Robot competition | ShinyRed | Robotics Chat | 2 | 23rd February 2008 02:21 AM |
| Base Robot Body | Krumlink | Robotics Chat | 6 | 2nd January 2008 05:09 PM |
| Nifty balancing robot | blueroomelectronics | Robotics Chat | 9 | 28th November 2007 04:32 AM |
| Pole balancing robot | IsoLator | Robotics Chat | 5 | 1st April 2005 12:08 AM |
