+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 23
Thread: My Robotic Arm
  1. #1
    baberjaved Newbie
    Join Date
    Sep 2007
    Posts
    73
    Default My Robotic Arm
    Heres' a picture of my Robotic arm.. Comments Please! I Still have to make the software for it and the End Gripper is also under construction at the moment. =)
    Can anyone tell me how can I find out exactly how much torque would be required at any joint of my arm and see if my Stepper motor can provide that much torque or not... Otherwise as the weight is quite a lot maybe I'll have to use some other motor (or maybe I can use Gears? If yes I dun know how :s)
  2. #2
    Marks256 Excellent Marks256 Excellent Marks256 Excellent Marks256 Excellent Marks256 Excellent
    Join Date
    Jul 2006
    Location
    Minnesota, USA
    Posts
    2,390
    Looks very nice! Let us know how it turns out! Also, please post schematics for your controller, and the software, if it is ok with you, of course.
    There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
  3. #3
    theinfamousbob Okay
    Join Date
    Apr 2005
    Location
    Cleveland, Ohio, USA
    Posts
    546
    Blog Entries
    2
    Here's a Wikipedia article on torque:
    http://en.wikipedia.org/wiki/Torque
    Basically, figure out how much your arm weighs and how far it is from the hub of the motor. Compare this to the torque rating on the motor and go from there. (Think I worded that properly; feel free to correct me. )
    -Ian
  4. #4
    ikalogic Good ikalogic Good ikalogic Good
    Join Date
    Dec 2003
    Location
    Limoges, France
    Posts
    632
    hello,
    Nice work.. however, if i was you, i would put all the motor in the base arm (the shoulder) and find out a way of transmitting power to the rest of the robot through wires. I did that last year, with bicycle brakes metallic wires, and it worked perfectly, we had a robot with movements controlled by 6 motors, and they were all in the base of the robot. This way you reduce inertia, also you need less power to move the 'end effector' of your arm.
    good luck and keep us posted
    Ibrahim Kamal
    check my electronics and robotics page: http://www.ikalogic.com/
  5. #5
    baberjaved Newbie
    Join Date
    Sep 2007
    Posts
    73
    Quote Originally Posted by ikalogic
    hello,
    Well I'm tryin to Run this thing now and The torque provided by the motor is way too less to lift the arm up...ikalogic your idea is very good and I would like to implement it in my arm but now that its already made I don't know how can I? =/
    Anyideas to solve this torque issue? I need the motors to move this.. but the weight is just too much =/
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,746
    Quote Originally Posted by baberjaved
    From the look of it you're trying to use stepper motors at the joints?, there's no way you can ever make that work, stepper motors are weak to begin with, and you're gearing them up a lot and making them MUCH weaker.
    I can only suggest you scrap it entirely and start again, this time give some thought how to make one - and test before you build it.
  7. #7
    baberjaved Newbie
    Join Date
    Sep 2007
    Posts
    73
    means there's no way I can add Gears and produce enough torque to make this thing work?
  8. #8
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,672
    Blog Entries
    5
    Sure why not, but you're going to have do some radical changes to make it work. Pulleys / chains might be the way to go, High torque motors for the heavy bits (steppers won't do it, not cheap ones anyway)
    Counterbalancing goes along way too.
    Here's the old Armdroid1
    http://www.senster.com/alex_zivanovi...roid/index.htm
    Bill
    Smart Kits build Smart People
  9. #9
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,746
    Like Bill says, you would need to rebuild it entirely - your existing model also looks incredibly heavy?.
  10. #10
    picbits Excellent picbits Excellent picbits Excellent picbits Excellent picbits Excellent
    Join Date
    Jan 2007
    Location
    Northants, United Kingdom
    Posts
    1,160
    Timing pulleys and belts are the way to go here.
    Not cheap though.
  11. #11
    baberjaved Newbie
    Join Date
    Sep 2007
    Posts
    73
    Quote Originally Posted by Nigel Goodwin
    The ARM itself is not that heavy but the motors are...
    you mean One Motor cannot even lift the weight of the rest of the motors?
  12. #12
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,672
    Blog Entries
    5
    It's because it's a 3rd class lever, the fulcrum has to support the entire weight of the arm.
    Take a yardstick and add a 1kg weight to the end and hold it out at arms length. Heavy isn't it. Welcome to physics 101.
    http://www.phy.cmich.edu/people/andy...s/Chapter7.htm
    Bill
  13. #13
    Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    Quote Originally Posted by blueroomelectronics
    A Class 1 fulcrum usually has a Mechanical advantage of less than 1, 1 exactly, or more than 1. A class 2 Has A MA of more than 1 Always or Exactly 1, but never less. A class 3 Lever has a MA of 1 or less, but never over 1.
    Wow I actually did learn something in HS so far
    IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
  14. #14
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,746
    No, because (as Bill's diagrams show) they are at a massive mechanical disadvantage, and steppers are only low power anyway.
  15. #15
    NightFalcon90909 Okay
    Join Date
    Mar 2008
    Location
    PA, USA
    Posts
    27
    Nice solid construction! In fact, from the sounds of the other comments, too solid!
    Firstly, torque = force * distance, force = mass * acceleration, acceleration = the change in position divided by the change in time.
    So you could do some measurements to find out just what kind of torque you were looking at here.
    Secondly, as has been suggested, you should looking to gears and chains. You could have all your motors at the base, and using a series of chains or even simple strings connected to winch type deals, really decrease the amount of weight you are dealing with.
    If it is broken, let's fix it.
    If it is working, let's make it better.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. robotic arm
    By hiyan in forum Robotics Chat
    Latest: 16th December 2008, 02:31 PM
  2. Robotic Arm
    By happytriger2000 in forum Robotics Chat
    Latest: 26th March 2008, 04:37 AM
  3. color sensor for robotic arm
    By Mortalo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th March 2008, 01:09 AM
  4. What is the best CRC for under arm Deodorant
    By Richard Principal in forum Chit-Chat
    Latest: 11th March 2008, 08:57 AM
  5. Which PIC for Robotic Arm?
    By baberjaved in forum Micro Controllers
    Latest: 8th September 2007, 08:28 PM
Tags for this Thread
