Old 24th March 2008, 09:03 AM   (permalink)
sckooi is on a distinguished road
Default line follower sensor problem... pls help...
hi... i wish to ask some line sensor problem. now i do AGVs project. what kind of line sensor can auto adjust the sensitivity? for example, i wan the sensor auto tune the sensitivity when face the floor colour is almost similar with line colour. And show me the circuit diagram for line follower sensor.
Thx a lot....
sckooi is offline   Reply With Quote
Old 24th March 2008, 03:02 PM   (permalink)
NightFalcon90909 has a spectacular aura about
Well I'm sure this is possible,l but I'm not sure how to do it automatically. Manually, you could use a comparator, and could just adjust the voltage going to the comparator that the input from the line would be compared to.
If it is broken, let's fix it.
If it is working, let's make it better.
NightFalcon90909 is offline   Reply With Quote
Old 24th March 2008, 08:52 PM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
Thx a lot....
Rules to follow when posting:
Proper Punctuation
No Text Speak
No using Plz, thx or Improper language, aka the (...)
Also, what have you done so far? Nobody is wanting to help you when you ask "Show me complete circuit thx". That does not show how much effort you have put into it. You should get a zero on your project.
MechTronics
Krumlink is online now   Reply With Quote
Old 25th March 2008, 02:11 PM   (permalink)
One more rule to follow when posting:
-Always try to be kind to newcomers. Aim for an encouraging, helpful tone. Otherwise, no one will want to stay.
For such an active member, Krumlink, I am surprised.
The ellipsis (...) is a perfectly legal English punctuation mark, and it is unfair to discriminate against someone because they write "ur" instead of "your." He said much more than just "show me a complete circuit thx." He mentioned that he was trying to design a circuit that would automatically adjust its sensitivity. That is a valid and interesting proposal.
Krumlink, try to be kind!
Old 25th March 2008, 02:43 PM   (permalink)
NightFalcon90909 thank ur reply...
http://www.kmitl.ac.th/~kswichit%20/LFrobot/LFrobot.htm
i will use this line follower circuit as show link above. but not sure that circuit can work or not? is it i can use that variable resistor (inside the line follower circuit) to adjust the sensor sensitivity? What type of comparator need to use? LM324? and what types sensor also... please advide me which model? thanks...
Old 25th March 2008, 03:29 PM   (permalink)
That circuit should work fine.
As far as sensors, you could definitely set up the sensors as shown in the picture on that page-
The 20 K var resistor there will let you adjust the sensitivity- read up on comparators if you are interested in how, and you probably should be if you are going to have to explain this project to anyone ;-) It's better to understand how comparators work anyway, you'll use them a lot. For the comp chip, I'd say use the LM339.
For the sensors, you could use the sensors that he used-
TX would be a infrared LED, and RX would be an IR Transistor.
You could also buy an IR LED and an IR Transistor in a package already... that is easier to interface.
Old 25th March 2008, 06:31 PM   (permalink)
Experienced Member
kemo0o is on a distinguished road
I THINK THAT YOU WILL FIND HELP THERE
http://www.ikalogic.com/cat_robot_navigation.php
IT HAS ALOT ABOUT ROBOT NAVIGATION
kemo0o is offline   Reply With Quote
Old 29th March 2008, 09:04 AM   (permalink)
hi...
i trial to construct the circuit as show above. i found my sensor without any response. why?
is it sensor angle problem? is it i can test the sensor without the assembly code? can teach me how to test the sensor after build the circuit? thanks...
Old 29th March 2008, 10:57 PM   (permalink)
Debugging time eh?
Make sure everything you have is hooked up to an appropriate amount of power.
Shine the IR LED directly at your receiver. If it doesn't work, you have a faulty receiver.
Old 30th March 2008, 09:20 PM   (permalink)
Experienced Member
ikalogic is just really niceikalogic is just really niceikalogic is just really nice
Send a message via MSN to ikalogic Send a message via Skype™ to ikalogic
Implementing auto adjustment is quite a challenge, because not only you have to be able to 'read' the current condition, you also need to have a mean of changing the threshold of your sensor, in other words, you need a DAC and an ADC! good luck!
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline   Reply With Quote
Line Follower Sensor Set-up Klitzie Robotics Chat 3 11th March 2008 01:04 PM
Line Follower Design Challenging Problems Michael Chua Robotics Chat 1 2nd March 2007 06:40 AM
line follower whit atmega8 Igor Moreira Robotics Chat 23 1st November 2006 12:34 PM
line follower help owika Micro Controllers 18 14th April 2005 03:48 PM
Help with a line follower! nestor Robotics Chat 2 5th October 2004 05:06 PM
