Old 16th March 2008, 08:30 PM   (permalink)
Experienced Member
ahmedragia21 is an unknown quantity at this point
Default Line following zig zag
Hi, im trying to follow a line using 6 sensors and it does not follow the line smooth and the motors are so fast really ... and one motor is faster than the other .. how do i solve that problem ? also when the robot is positioned like figure 2 and make it to follow the line it doesnt ... it just cross it as it and doesnt follow it !!
ahmedragia21 is offline   Reply With Quote
Old 16th March 2008, 09:04 PM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
Try just hooking the motors up to the same power source (no circuitry, just direct power). If they drive straight, then it is the circuitry's fault.
MechTronics
Krumlink is offline   Reply With Quote
Old 16th March 2008, 09:07 PM   (permalink)
Experienced Member
i did that , it still deviates to right ...
but why that zig zag happens ? also how do i slove the second figure problem ?
thanks
Old 16th March 2008, 09:18 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Friction in the gear train.
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 16th March 2008, 09:28 PM   (permalink)
Experienced Member
Hank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of light
I'm glad you brought that up. I've noticed that depending on their orientation, the Tamiya gearboxes can get noisy. I've yet to determine the source of the noise, though. Maybe it's the crown gear on the motor? Any thoughts and/or solutions?
Hank Fletcher is offline   Reply With Quote
Old 16th March 2008, 09:33 PM   (permalink)
Experienced Member
I tried cementing the bushings on one unit, didn't notice any real difference in noise and probably just simply increased the friction.
12000RPM is going to be noisy with a plastic open frame gearbox & motor. The crown gear & tiny pinion gear would be my guess too.
I did find sometimes the motor presses too hard on the crown gear, I've added thin foam shims to the Mongoose manual and this helps alot.
Bill
Old 17th March 2008, 11:29 AM   (permalink)
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
thanks
I don't know whether robots do this, but if you want to stabilize a vehicle and help it go straight, put a little toe-in to the front wheels. That way, if it deviates to the right, the left wheel will be more crossed to the direction of travel (i.e., create more drag) and device will tend to self-correct. A neutral setting is OK, but if you have any toe-out, it can become quite unstable.
Maybe your robot has toe-out on just one wheel? One thing you can check is whether with the motors disconnected does the robot coast in a straight line?
John
jpanhalt is offline   Reply With Quote
Old 20th March 2008, 01:05 AM   (permalink)
NightFalcon90909 has a spectacular aura about
"I'm glad you brought that up. I've noticed that depending on their orientation, the Tamiya gearboxes can get noisy. I've yet to determine the source of the noise, though. Maybe it's the crown gear on the motor? Any thoughts and/or solutions?"
Know what you mean... I got a double, and one of them makes a racket to wake the dead, the other one is nice and cooperative. I can only assume it is a due to minute differences in positions of the gears... no amount of grease helps...
If it is broken, let's fix it.
If it is working, let's make it better.
NightFalcon90909 is offline   Reply With Quote
Need advice about this AC Line Current Detector Avocado Electronic Projects Design/Ideas/Reviews 6 21st March 2008 05:36 PM
DS1302 with PIC16f877 program RasCreationKing Micro Controllers 28 3rd May 2007 12:03 PM
QBasic Serial Port Control DigiTan Micro Controllers 3 5th January 2006 11:31 PM
2 line telephone patcher / switcher .. help please rca507 Electronic Projects Design/Ideas/Reviews 1 20th February 2004 04:19 AM
LCD 4 Line 40 Character Interfacing rwamser Electronic Projects Design/Ideas/Reviews 5 28th November 2003 12:44 AM
