| Experienced Member | Hi, im trying to follow a line using 6 sensors and it does not follow the line smooth and the motors are so fast really ... and one motor is faster than the other .. how do i solve that problem ? also when the robot is positioned like figure 2 and make it to follow the line it doesnt ... it just cross it as it and doesnt follow it !! |
| Moderator | Try just hooking the motors up to the same power source (no circuitry, just direct power). If they drive straight, then it is the circuitry's fault.
__________________ MechTronics |
| Experienced Member | i did that , it still deviates to right ... but why that zig zag happens ? also how do i slove the second figure problem ? thanks |
| Experienced Member | Friction in the gear train. |
| Experienced Member | Quote:
| Experienced Member | I tried cementing the bushings on one unit, didn't notice any real difference in noise and probably just simply increased the friction. 12000RPM is going to be noisy with a plastic open frame gearbox & motor. The crown gear & tiny pinion gear would be my guess too. I did find sometimes the motor presses too hard on the crown gear, I've added thin foam shims to the Mongoose manual and this helps alot. |
Maybe your robot has toe-out on just one wheel? One thing you can check is whether with the motors disconnected does the robot coast in a straight line? John | |
| New Member | Quote:
Know what you mean... I got a double, and one of them makes a racket to wake the dead, the other one is nice and cooperative. I can only assume it is a due to minute differences in positions of the gears... no amount of grease helps...
__________________ If it is broken, let's fix it. If it is working, let's make it better. | |
| Need advice about this AC Line Current Detector | Avocado | Electronic Projects Design/Ideas/Reviews | 6 | 21st March 2008 05:36 PM |
| DS1302 with PIC16f877 program | RasCreationKing | Micro Controllers | 28 | 3rd May 2007 12:03 PM |
| QBasic Serial Port Control | DigiTan | Micro Controllers | 3 | 5th January 2006 11:31 PM |
| 2 line telephone patcher / switcher .. help please | rca507 | Electronic Projects Design/Ideas/Reviews | 1 | 20th February 2004 04:19 AM |
| LCD 4 Line 40 Character Interfacing | rwamser | Electronic Projects Design/Ideas/Reviews | 5 | 28th November 2003 12:44 AM |
