Hi. i've searched other topics but couldnt find something related to my problem. for my robot project, i am driving a dc motor with pwm. when i test the l298 (with or without pwm) i see that the voltage between the output pins are not 12 volts. it is about 1 volt lower. (driving l298 with 12 volts). is this a normal thing? or there is a possible solution? i thought that motor is making a loading but i couldnt solve it using a buffer.
Experienced Member
Didn't you look at the datasheet for the L298?
With a 1A load, its output high voltage loss is max 1.7V and its output low voltage loss is max 1.6V. Its max total voltage loss is 3.2V. With a 2A load, its output high voltage loss is max 2.7V and its output low voltage loss is max 2.3V. Its max total voltage loss is 4.9V.
Uncle $crooge |
i should have. thank you for reply.
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| Power supply | Electronics4you | General Electronics Chat | 23 | 2nd March 2007 11:07 PM |
| LED voltage drop | Peepsalot | General Electronics Chat | 14 | 28th March 2006 05:27 PM |
| Voltage reg or voltage reference. | Screech | General Electronics Chat | 4 | 13th May 2005 06:57 AM |
| resistor | andrew8485 | General Electronics Chat | 10 | 27th November 2003 03:23 AM |
