Hello. I recently built a bipolar driver using a L297/298 combo. I basically followed the datasheets given for the 297/298 and added some screw terminals and adjustments for control. I just finished assembling everything today, but I cannot get it to work. When powered on, the motor just vibrates and hums. I am using two separate computer power supplies to power the driver. One for the logic and one for the motor supply with the grounds tied together. I have the connection for SYNC left open, CLOCK going to a 250Hz 5V square wave, and CW/CCW grounded. I am certain that the motor is wired in the correct order. I have tried the driver with CONTROL enabled and disabled with very little change. I have not observed any smoke, excessively hot components, or anything else to suggest that the circuit is fried. I tested and made sure all the chips were getting power. I have attached a copy of my schematic that I made. Any advice would be greatly appreciated as to the validity of my schematic or suggestions for troubleshooting my issue. Thanks!
250Hz is way too fast. Use a 555 timer to trigger it at about 10 Hz until you get it working, then you can turn up the speed. Even manually single step it to start.
C:\WHUT ? Beware the asterisk * |
also, what voltages are you measuring on the motor outputs and the supply input voltages.
| Setting stepper motor to 'home' position. | MrNobody | Micro Controllers | 14 | 3rd October 2007 03:03 PM |
| Stepper Motor | netbug | Robotics Chat | 5 | 27th July 2006 05:11 PM |
| Stepper Motor Driving Using PIC16F74 | t_anjan | Electronic Projects Design/Ideas/Reviews | 0 | 31st January 2006 06:13 PM |
| Stepper code for PIC | raitl | Micro Controllers | 6 | 15th February 2005 01:44 PM |
| stepper motor | jim bro | Electronic Projects Design/Ideas/Reviews | 0 | 26th May 2003 08:54 PM |
