Old 20th March 2008, 02:44 AM   (permalink)
menirva is on a distinguished road
I build two h-bridge, both share the same voltage source (6VDC). Result is, the current output to drive a motor (one motor for each h-bridge) is so small.
Can someone give me some idea, how to drive two motor, without using so much voltage source? 1 voltage source for driving 1 motor, not really good in my opinion.
menirva is offline   Reply With Quote
Old 22nd March 2008, 01:29 AM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
Is your supply voltage for the h-bridge only 5V?
Then if you use 2A darlington transistors like the TIP110 and TIP115, the motor will receive no voltage when the darlingtons have their max allowed saturation voltage loss. But then the motor wouldn't use any current so the saturation voltage loss will be less than 5V but might be as high as 3V so the motor gets only 2V.
Old 19th April 2008, 10:13 AM   (permalink)
Originally Posted by KMoffett
If your Stop time can be equal to your Forward and Reverse times, then maybe you can use an 8-bit walking ring counter with OR'ed outputs.
Ken
What best to describe this circuit? A "what" circuit? What name best fit it?
Old 19th April 2008, 10:25 AM   (permalink)
Super Moderator
Sounds like your supply voltage is too low, use relays instead of transistors, you can't PWM but you get pretty well zero voltage loss to the motor.
Or use a DPDT relay for reversing, and a single transistor (or FET) for PWM.
Old 19th April 2008, 02:56 PM   (permalink)
Experienced Member
Even if TIP110 and TIP115 complimentary darlington transistors are used to drive the motor with up to 2A from a 6V supply, their saturation voltage will reduce the voltage of the motor to from 1V to 4V.
MOSFET For H Bridge Ayne General Electronics Chat 1 16th February 2007 12:08 AM
Need Help on High Current H Bridge pidot Robotics Chat 16 15th September 2005 06:46 AM
bridge rectifier batman Electronic Projects Design/Ideas/Reviews 2 15th December 2003 04:27 PM
Bridge Rectifier Current Rating -- How much is enough? hamfiles General Electronics Chat 6 6th August 2003 06:15 AM
Wireless network bridge monitoring circuit...need pointers. Goose Electronic Projects Design/Ideas/Reviews 0 17th February 2003 02:02 PM
