| New Member | I build two h-bridge, both share the same voltage source (6VDC). Result is, the current output to drive a motor (one motor for each h-bridge) is so small. Can someone give me some idea, how to drive two motor, without using so much voltage source? 1 voltage source for driving 1 motor, not really good in my opinion. |
| Experienced Member | Is your supply voltage for the h-bridge only 5V? Then if you use 2A darlington transistors like the TIP110 and TIP115, the motor will receive no voltage when the darlingtons have their max allowed saturation voltage loss. But then the motor wouldn't use any current so the saturation voltage loss will be less than 5V but might be as high as 3V so the motor gets only 2V.
__________________ Uncle $crooge |
| New Member | Quote:
| Super Moderator | Quote:
Or use a DPDT relay for reversing, and a single transistor (or FET) for PWM. | |
| Experienced Member | Even if TIP110 and TIP115 complimentary darlington transistors are used to drive the motor with up to 2A from a 6V supply, their saturation voltage will reduce the voltage of the motor to from 1V to 4V.
| MOSFET For H Bridge | Ayne | General Electronics Chat | 1 | 16th February 2007 12:08 AM |
| Need Help on High Current H Bridge | pidot | Robotics Chat | 16 | 15th September 2005 06:46 AM |
| bridge rectifier | batman | Electronic Projects Design/Ideas/Reviews | 2 | 15th December 2003 04:27 PM |
| Bridge Rectifier Current Rating -- How much is enough? | hamfiles | General Electronics Chat | 6 | 6th August 2003 06:15 AM |
| Wireless network bridge monitoring circuit...need pointers. | Goose | Electronic Projects Design/Ideas/Reviews | 0 | 17th February 2003 02:02 PM |
