| New Member | I am using TSOP1738 IR Receiver Module for creating IR Sensing Robot. It works with 38KHz. Can you tell me how to test the sensor circuit - Input and Output?? Thank you... |
| Experienced Member | Quote:
From the datasheet, it looks like you can just put +5V to pin 2, ground pin 1, and check the output from pin 3 when you shine an IR LED pulsed at 38kHz on it. Good luck, Torben | |
| Experienced Member | Use a TV/VCR remote to test it. I use a different module, but the output is normally high, and goes low when it receives pulses. I hooked an oscilloscope to the output pin, but you might see an LED flash or flicker... |
| IR obstacle detection using TSOP1738 with PIC16F628 | pkshima | Micro Controllers | 2 | 13th June 2007 12:08 AM |
| Tsop1738 | abbas1707 | Micro Controllers | 1 | 27th April 2007 06:39 PM |
