This is a discussion for setting up the ADC module in PIC16F684. For detail operation of ADC please refer to Microchip data.
There are five registers involved in ADC operation: ANSEL, ADCON0, ADCON1, ADRESH, ADRESL. We only need to set up ANSEL, ADCON0 and ADCON1. The conversion result will be stored in ADSEH and ADSEL. Please refer to block diagram (from Microchip data): ADC_Block.JPG We will set up the registers in the order of the red numbers in the diagram. HTML Code:
(1) Select analogue input. In our example, we chosed pin 11 of the chip,
which is AN2.
ANSEL= 0b00000100;
(2) Set CHS bits in ADCON0 to select the channel to connect to sample and
hold circuit.
ADCON0 <4:2> = _ _ _ 0 1 0 _ _
(3) Set voltage reference source in ADCON0<6>. 0= VDD, 1= Vref pin. We
choose VDD as reference. So,
ADCON0 <6> = _ 0 _ _ _ _ _ _
(4) Initiate ADC module by setting "1" in ADCON0 <0> ( doesn't mean A/D
conversion starts).
Set DO/DONE bit in ADCON0<1> to off, not starting conversion yet.
ADCON0<1>= 0. So,
ADCON0<1:0> = _ _ _ _ _ _ 0 1
(5) Set A/D conversion format, left or right justified, in ADCON0<7>. The
result of the conversion is in 10 bits and will be stored in ADRESH and
ADRESL register. Left justified is : xxxxxxxx xx000000
ADRESH ADRESL
Right justified is: 000000xx xxxxxxxx
ADRESH ADRESL
We choose left justified, so
ADCON0 <7> = 0 _ _ _ _ _ _ _
To sum up for ADCON0:
ADCON0= 0b00001001;
The setting with reference to the block diagram is complete.
When we want to start the conversion, we simply set GO/DONE bit to 1, ie
(6) GODONE= 1;
Next we have to set the conversion clock:
(7) Set the A/D conversion clock (TAD) in ADCON1 <6:4>.
We have to ensure a mimimum of 1.6 uS TAD for proper A/D operation.
For 4 MHz device frequency, we should select 8 Tosc (2.0 uS, which is >
minimum requirement). ADCON1 <6:4> = 001.
ADCON1= 00010000;
If we don't want to calulate this value, we can just set ADCON1 <6:4> to
x11. The TAD is 4 uS with this setting.
To sum it all up, we only need three C statments to set up the ADC.
Analogue input= AN2
Voltage reference source= VDD
Device OSC= 4MHz
C statments:
ANSEL= 0b00000100;
ADCON0= 0b00001001;
ADCON1= 00010000;
Next we will use this setting and connect a POT to AN2 to control 8 LEDs...... PS.Can someone please tell me how to attach a bigger picture on the same page.
May the force be with you. My project: Simple White Line Follower http://au.youtube.com/watch?v=8Z_MmrdH4oc http://i271.photobucket.com/albums/j...nefollower.jpg Last edited by Wingmax; 16th February 2008 at 05:07 AM. |
| PIC12F675 ADC Circuit help. | MERV | Micro Controllers | 4 | 16th January 2008 08:05 PM |
| ADC troubles | andy257 | General Electronics Chat | 4 | 2nd December 2007 05:49 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:48 PM |
| HS1101 capacitive humidity sensor; need nearly linear voltage to feed to a 1-wire ADC | FirefighterBlu3 | Electronic Projects Design/Ideas/Reviews | 5 | 19th October 2007 11:06 PM |
| 16F877 Timer0 Interrupt Affecting ADC | sebana | Micro Controllers | 13 | 12th September 2007 09:42 AM |
