Hi All,
I am working on a project and bought myself a couple of Hitec servos. I have now built an astable circuit using a 555 timer and controlling it with an input thats between 0 and 10v (10v makes the pulse 2ms and 0v makes it 1ms). When I tested it, the servo arm didn't move the 180 degrees I was expecting (when no power applied I can move it 180) I had a look at the datasheet for the servo and it says it has an operating angle of "40? one side pulse traveling 400usec" I am new to servos (as you can probably tell) and I was wondering, what does the "one side pulse" bit mean? I am uncertain as to whether it should travel only 40, or 80. yet while it doesn't travel the full 180 I was expecting, its certainly more than 80. The other thing is that in the instructions is says a control pulse of between 0.9ms and 2.1ms, if my circuit is giving out 1-2ms do I need to tune it to make the servo move further or is it moving to its fullest extent already. I appreciate you probably cant answer all of this, but any comments would be welcome! Cheers Shaun |
Servos aren't designed to move 180 degrees, probably 90 degrees is about the most?, although by extending the pulses (both less and more) you can get them to exceed their design limits considerably.
hi Shaun,
Post a link to the datasheet.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Regards Shaun |
here it is http://www.hitecrcd.com/product_file...3/HS5245MG.pdf Rehards Shaun |
I have tried posting two messages with a link to the datasheet, but neither have appeared, and the message that comes up afterwards goes away too quick for me to read! maybe they have to be approved?
the servo is a Hitec HS5245MG. Regards Shaun |
Here is an extract:
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:23 AM. |
regards Shaun |
This looks a better link: http://www.servocity.com/html/hs-524...ital_mini.html This gives an explanation. http://www.pc-control.co.uk/servo_control.htm
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 11th January 2008 at 01:33 PM. |
Thanks Eric,
It would seem then that it has 90 degree motion range. I will measure it anyway just to be sure. I am also thinking of getting an Oscilloscope to test the pulse from my circuit. The pc-control article is a good read and explains it well, I am still unsure about what a one side pulse is... but I think I'll just drop that one! Regards Shaun |
| Servo problems | bananasiong | Micro Controllers | 0 | 16th September 2007 02:15 AM |
| Servo Controll... In reverse? | savage | Micro Controllers | 9 | 1st December 2006 03:10 PM |
| Replacing RC Servo w/ Custom PCB (Open Servo) | dknguyen | Electronic Projects Design/Ideas/Reviews | 3 | 29th May 2006 02:48 AM |
| Help required with servo motor controller | mayhem | Robotics Chat | 3 | 26th May 2006 04:21 PM |
| Servo Motor Help Needed!!!! | potpotpotpot | Robotics Chat | 10 | 10th May 2006 07:53 PM |
