I having problem in programming. As we know that we need to keep sending pulses to keep the servo motor keep at a degree of angle that we want. The problem is how can i still holding the angle of the servo and in the same time make others servos turn? Because of the programme run line by line so I can't order 2 or more servos to turn at the same time. Do you have any idea to make it happen?
Thanks. |
Search the forum for the 33 servos thread.
I also having the same problems with you. The 33 servos are not using the C language to programme, so I not really understand how it works.
Thanks |
How many servos do you chaps need to control? What microcontroller are you guys using?
I think someone did provide some C code in that post, or maybe in the one I started about 18 servos. At any rate, you can multiplex the signal wire or just use multiple pins of the uC. Since the signal is max 2ms and with 20ms period, you can get up to 9 servos (considering loss of time in instructions) going with one 16-bit timer. I opted to using one large PIC instead of a multiplexer, so the pcb is easier to design and debug.
I try to control 8 servos using PIC16F877A.
TheV,
In that case, read Ambient's comment. |
You could use several different methods.
One relatively simple / high performance / low overhead method uses the CCP module in "compare" mode, a small ISR "engine", and a 9 element array. The first eight Servo array element values of 600..2400 are used to output a pulse to each Servo pin on PORTB. The ninth array element is used for the Servo period "off time" (20000 usecs minus the cumulative servo pulse on time values). The listing below is the pseudo C code for an 8 channel 16F628A controller. Let me know if anyone needs to see the assembly listing. Care must be taken to update the CCPR1H register before the CCPR1L register to avoid a false "compare" trigger. The C code as written won't do that but my assembly language code does handle this properly. Good luck with your project. Mike Code:
;* K8LH Crazy-8 HiRez 8-channel (PORTB) Servo Algorithm *
;* 1800 1.0-usec steps from 600..2400-usecs per Servo (4 MHz) *
; unsigned char n = 0;
; unsigned int Servo [] = { 1500, 1500, 1500, 1500, 1500,
; 1500, 1500, 1500, 20000 };
; unsigned char Shadow = 1;
; void isr_hi ()
; { LATB = Shadow; // output new Servo pulse
; CCPR1 += Servo[n]; // update "match" period value
; PIR1bits.CCP1IF = 0; // clear CCP1 interrupt flag
; Servo[8] -= Servo[n]; // adjust end-of-period time
; Shadow <<= 1; // prep for next channel
; n++; // increment array index
; if (n = 9)) // if end-of-cycle
; { n = 0; // reset array index
; Servo[8] = 20000; // reset the 20 msec period
; Shadow = 1; // reset Shadow to '00000001'
If it will help you that's my control programm in picBASIC
works for 877a @ 20mhz raw code, it's many ways to speed it up a var byte b var word s0 var word s1 var word 's0-s5 variables for servo position, usually 50-250, but can be 0-255 s2 var word ' for fast control chip must run at 20mhz, but command PULSOUT s3 var word 'adjusted for 4mhz xtal, so we need to multiply a value by 5. s4 var word 'that's why we need a WORD variable (0-65535) s5 var word DEFINE OSC 20 'xtal at 20mhz, have effect for HSERIN, but not pulsout DEFINE HSER_RCSTA 90h 'Enable transmit register DEFINE HSER_TXSTA 24h 'high baudrate, 115.2kbps DEFINE HSER_CLOERR 1 'automatically clear overrun buffer DEFINE HSER_BAUD 115200 s0 = 1250: s1 = 715: s2 = 750: s3 = 750: s4 = 750: s5 = 750 'start values of servo positions (*5!!!) low portc.0 low portc.1 low portc.2 'all of it can be 'portc = 0' low portc.3 low portc.4 low portc.5 au: 'START pulsout portc.0, s0'*5 'pulse on pin C.0 for s0 time (already multiplied by 5) pulsout portc.1, s1'*5 pulsout portc.2, s2'*5 pulsout portc.3, s3'*5 'on all of them... with it's value pulsout portc.4, s4'*5 pulsout portc.5, s5'*5 auNEW: hserin 50, au, [a,b] 'receive two characters serially, place them in a and b variables 'if not received within 50msec, goto AU rcsta.4 = 0 'turn off receiver rcsta.4 = 1 'then turn it back on, like clearing the buffer b = b * 5 'a - number of servo, b position (0-255!), for our purpose we have to multiply it if a = "1" then s0 = b: pulsout portc.0, s0 'you need to send serially just two characters, first, number of if a = "2" then s1 = b: pulsout portc.1, s1 'servo, second, position if a = "3" then s2 = b: pulsout portc.2, s2 'example, send "2" then send "150", then "1" and "50" and go on if a = "4" then s3 = b: pulsout portc.3, s3 ' if a = "5" then s4 = b: pulsout portc.4, s4 if a = "6" then s5 = b: pulsout portc.5, s5 goto auNEW it's much time to send programm again to AU for every pulsout again, possibly a new values of a and b already in the buffer, we need to get them fast, preventing buffer overflow ------------------------------------------------------------ here is the whole device at work http://uk.youtube.com/watch?v=8sWki9Y8S8Y Last edited by Airrr; 5th January 2008 at 06:37 PM. |
Airrr,
Nice video. Code could use some comments though. Regards, Mike |
No problem!
EDIT: Nice video for sure. Nice work. I would like one of those (my cats and dogs would fear me for a change ;D ). Last edited by mramos1; 6th January 2008 at 01:02 PM. |
| Drive 33 Servos With One PIC + USART | wschroeder | Micro Controllers | 40 | 14th July 2008 02:22 PM |
| Quik PIC Programming kit | Krumlink | General Electronics Chat | 5 | 27th January 2008 11:27 PM |
| Capturing and reproducing audio with a PIC | Fred.Amoson | Micro Controllers | 14 | 14th December 2007 08:21 PM |
| High ADC sampling rate PIC, 18F needed? | bananasiong | Micro Controllers | 24 | 28th October 2007 12:13 PM |
| Controlling servos with PIC16F84A | Ostekjeks | Robotics Chat | 3 | 25th February 2005 10:06 AM |
