Old 6th November 2007, 04:10 AM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
Question Breakout Board Design (submit your ideas)
I was thinking (yes I know, what a surprise) and I wanted to make a Robot PCB using the PCB Artist Software (my PCB maker uses it). I was wondering what Ideas people would want on it. It is going to be a 5x5 inch Square board, and If you would like to contribute ideas for it, go ahead and shoot .
Some Starter Ideas:
on board H bridge (using ?)
V Regulator (using ?)
If I can get enough good ideas, maybe I will make a kit
MechTronics
Krumlink is offline   Reply With Quote
Old 6th November 2007, 04:26 AM   (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
5"x5" is pretty big. Personally, I'd shrink the board and have the motor drivers separate since they are so robot dependent. BUt if you really want to stick one on, have at least 2, along with voltage/current sensing, gate drivers, maybe encoder inputs, and probably 5A or greater, since a 5x5" board is probably a fairly large robot anyways.
If you're talking more of a general "control board" for a robot, then forget about all the really robot specific stuff like the H-bridge (get that separately and properly sized to each robot). Something like buffers for the ADC inputs is a must since every uC ADC I've seen requires really low input impedances. An ICD jack, UART-PC level shifter, I2C line extender/driver (for kicks), CAN bus (for kicks also, but if you build other electronics you might want to base all your other circuits around this bus anyways). Really fancy addons are things like 3-axis accelerometer, 2-axis gyros, configurable lowpass filters for the ADCs, temperature sensor. Don't forget to leave the PWM/output compare pins free for controlling servos as well as the input compare pins for measuring input square waves. Math coprocessor perhaps if your uC is weak in that department. Set-and-forget PWM ICs perhaps.
Old 6th November 2007, 04:42 AM   (permalink)
Moderator
Wow, getting some good feedback already
I would like to have it mountable with a Tamyia Gearbox, so you could just mount the board right onto it.
The ICD is a good idea, what PIC would you like to see it using? I was thinking of having the PIC pinned out, then have a small breadboard mounted on it, so you could easily prototype with it. It would have a pre made H Bridge on it, so you would just have to Code N Go!® (I call that phase )
MechTronics
Old 6th November 2007, 04:46 AM   (permalink)
Experienced Member
I like dsPIC30F4011 or dsPIC30F4013...but that's just me. THere's always the argument of the best part to use is the one that's just good enough to do the job, and not overkill.
Old 6th November 2007, 04:59 AM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Krumlink search this site and tell me if they have anything similar to what you want to do.
http://www.pololu.com/
Bill
Smart Kits build Smart People
Old 6th November 2007, 11:03 AM   (permalink)
Moderator
Actually, not at all. I will more fully explain my idea later.
MechTronics
Digital Weight Scale Design Ideas Johnson777717 Electronic Projects Design/Ideas/Reviews 12 18th August 2007 04:40 PM
Design Ideas instruite General Electronics Chat 0 4th August 2005 02:06 AM
Need help ro design a "heart rate monitor" circuit elrikdo Electronic Projects Design/Ideas/Reviews 1 18th May 2004 08:21 PM
Need help ro design a "heart rate monitor" circuit elrikdo Electronic Projects Design/Ideas/Reviews 0 18th May 2004 07:20 PM
DIGITAL CLOCK HARDWARE DESIGN (PLS CORRECT) Jay Duluguin Electronic Projects Design/Ideas/Reviews 4 18th February 2004 04:33 PM
