Old 5th November 2007, 09:06 AM   (permalink)
Lightbulb Obstacle !
Hi All ,
i have a 4 wheeled robot with Ultrasonic sensor 4 stocks .
my problem is :
suppose that all the 4 sensors for some reason couldn't detect an sepecific obstacle in front of it ..... so my robot will crash with this obstacle although the ultrasonic sensor cannot detect it .
how to solve this problem ..... i thought of using SPDT switches with the ultrasonic sensors.
do you have a better idea ?
watzmann is offline   Reply With Quote
Old 5th November 2007, 09:23 AM   (permalink)
You could use 'whiskers', like a cat, that operate small switches - it's a common solution on simple robots.
However, if your ultrasonics are that bad, perhaps you should try and get them working properly?.
Old 5th November 2007, 10:10 AM   (permalink)
no they are not so bad , but it's just a case which may happen .....may be because of a very thin rod ...... any upnromal obstacle.
i don't know what is whisler's is , but i'll search on google about it .
Old 5th November 2007, 10:13 AM   (permalink)
yes i got what you mean , but how to build them , i think they need a very sensitve switches
Old 5th November 2007, 11:49 AM   (permalink)
'Whiskers' are springy wires, bit like the wire use in guitars or piano's.
You can make a simple switch, by bending a piece of wire in a loop, use a screwdriver as a former and wrap the wire round in a loop, say 4mm diameter.
Then get a straight piece of wire and pass it thru the loop, [not touching]
The straight piece is one side of your switch and the loop the other.
When the straight piece of wire hits an obstruction it bends/deflects and touches the loop, closing the 'switch'
Bend the straight piece of wire into a curve to suit your robot.
The problem with guitar/piano wire its hard to solder, you may have to use a mechanical screw connection.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 5th November 2007, 07:03 PM   (permalink)
Just have a SPDT Microswitch as an interrupt for the Ultrasonics. Easy.
Krumlink is online now   Reply With Quote
obstacle detection Ali Az Zobui Robotics Chat 4 21st September 2007 01:32 AM
obstacle sensing using ir t_sanoop Robotics Chat 5 27th April 2006 12:05 PM
Robotic obstacle detection infinity Robotics Chat 11 29th September 2004 05:22 PM
i need info about obstacle detection bortoukala Micro Controllers 1 20th May 2004 03:09 PM
Getting over an obstacle giv_er Robotics Chat 2 23rd February 2004 04:28 PM
