For my *secret* robot I want to use a small very compact easy to build freeformable H-Bridge that can handle up to 1 amp at 9V. The robot it will be in will be *secret* hence I must be very *secretitive* about this *secret* project, codenamed *secret* robot. I will post the results of this *secret* robot and its *secret* specifications once I complete the *secret* robot. I would rather use the 2N2907A and the 2N2222A because I have over 100 of each that I got from my favorite supplier, which is *secret*. I would prefer the H-Bridge to have a *secret* device inside of it that would prevent me from smoking it, or what I *secretly* call the anti-smoke device, which name was reccently de-*secret*-itized.
I willl use my *secret* robot for the good of mankind |
Try a SN754410 1.2A drivers, with diode clamps.
I dont know....
What company makes it? Does maxim make motor Drivers? I really like TI and Maxim |
TI makes the SN754410
http://focus.ti.com/docs/prod/folder.../sn754410.html and the L293 http://focus.ti.com/docs/prod/folders/print/l293.html There are others, but they are a *secret*!
--- The days of the digital watch are numbered. --- |
If your secret robot is so secret keep it secret and leave us all alone
" The only way to avoid human error is to avoid the use of humans" |
lol ok it is for my walking robot
Krumlink, you need to loosen up and share your ideas for your walker robot. It's easy to be tempted into coveting ideas, for fear that someone might "steal" them (or accuse you of stealing them), but that fear has a false basis. Strangely enough, you're much more likely to come up with an original idea the more you share it with others. Also, by posting your work and process on this forum, you can establish precedent for your ideas by way of witnesses should the originality of your project be called into question. Think of sharing your ideas as a type of pre-emptive protyping. Everyone has their own perspective, so when you share ideas with other people there's an opportunity there for people to point out how things can fit together in a way you otherwise might not have thought about. That's a bonus, not a threat, to your inventions. I'm blown away by how many times the way around a seemingly insurmountable task for me has been elucidated by someone with a simple solution, just because they were able to see what I was trying to do from a different point of view. That's the benefit of collaboration, and that in turn is the virtue of getting along with other people: the sum of collective minds tends to be greater than the parts. Last edited by Hank Fletcher; 30th October 2007 at 12:17 PM. |
Might as well build something like the Parallax walking bot. It uses two servos and although it's designed for the BASIC Stamp any small micro should have no problem with a pair of servos. The key word is "micro" would be tricky to do it with discreet logic.
If I remember correctly, the 2N2222A will don't pass 800mA and the motor will draw a lot more than that when started.
You could parrallel a load of them using 0R5 emmitter ballancing resistors but you're better off using MOSFETs.
Good chip, but the diodes aren't needed(page 2 in datasheet). I've used them before, and they can be stacked if the load is too high. Looks like they're 1.1A continuous.
-Ian |
The schematic of the outputs show a pair of diodes.
http://www.kronosrobotics.com/an101/AAN101.shtml edit: I read your message wrong, thought you said the diodes were needed... Last edited by blueroomelectronics; 31st October 2007 at 05:57 AM. |
[quote=blueroomelectronics]Might as well build something like the Parallax walking bot. It uses two servos and although it's designed for the BASIC Stamp any small micro should have no problem with a pair of servos. The key word is "micro" would be tricky to do it with discreet logic.
[quote] Thanks for the suggestion. It's a very good book, can be downloaded too.
May the force be with you. My project: Simple White Line Follower http://au.youtube.com/watch?v=8Z_MmrdH4oc http://i271.photobucket.com/albums/j...nefollower.jpg |
THe ratings are 60ma no load, and 600ma stall at 6V. I am building this "style" of walker:
![]() I have seen books saying to use the SN74AC245N Paralleled up to create H Bridge Drivers, but my motors wont work with these, so I was thinking of making this kind of H Bridge: ![]() Only thing is that you remove the Schmitt Inverters on it. I will use the one above, beacuse it is easily free formable and easy to make. |
Why do you want to build a H-Bridge from transistors when you can buy the SN754410A suggested by Bill?
I can only speak from my experiance. I have built the Miss Motor H-Bridge using 2N2222's and 2N2907 transistors. It is not a great preformer. The SN754410A transfers more power at a given voltage. If you are going to use transistors at least use the ones I mentioned above. David Cook compares transators here. The ZTX ones are nice but spendy. Do not think they have samples. |
I was going to use the 2N2222 and 2N2907s, because I got a ton of em.
| Query about a project of ''Mobile phone controlled robot'' | kau.shah | Electronic Projects Design/Ideas/Reviews | 2 | 6th October 2006 09:33 AM |
| Good Robot Starter Kits? | Sharewareisland.com | Robotics Chat | 8 | 22nd April 2006 05:15 PM |
| Help me searching some good project with good practical appl | shubhendu bhardwaj | Electronic Projects Design/Ideas/Reviews | 1 | 11th February 2006 10:34 AM |
| mobile robot | Anonymous | Robotics Chat | 5 | 19th July 2003 10:18 PM |
| holiday project- robot | Pumbaa | Robotics Chat | 3 | 3rd January 2003 10:59 AM |
