Old 27th October 2007, 10:56 AM   (permalink)
Unhappy can't drive my DC motor
Hello all,
this is my first time in this forum and my english is not so well, so i hope for understanding.
I have a DC motor from some drill that work on 18V. I want to driving this motor with atmel 89c5131, I use L293D but it get warm up too much and the motor doesn't work, I think that the reason is too much current to push.
I need help with this, what i need to do for the motor will work.
bar_shay is offline   Reply With Quote
Old 27th October 2007, 10:58 AM   (permalink)
You need a MUCH more powerful driver device - an L293 is only for tiny motors. Do you want to mdrive it both ways?, if you do you will require an H-Bridge.
Old 27th October 2007, 11:03 AM   (permalink)
Yes, I want to drive itboth ways.
I need a cheap solution because i dont have enough budget
Old 27th October 2007, 11:45 AM   (permalink)
Have a look at http://www.bobblick.com/techref/proj...e/hbridge.html for some ideas.
Old 27th October 2007, 12:41 PM   (permalink)
thanks, I think that it will help
Old 27th October 2007, 04:13 PM   (permalink)
At my HS robotic club, we use VECTORS, which can drive 65 Amp Motors
They cost $100
Krumlink is offline   Reply With Quote
Old 27th October 2007, 08:22 PM   (permalink)
They cost $100
Did you not read
I know I saw that, I reccomend that boblick site, or just use a H bridge using some High Amp Transistors/mosfets.
Old 28th October 2007, 10:06 PM   (permalink)
Originally Posted by bar_shay
Hello all,
May be you should work out the current drawn by the motor first, then you'll be more certain about what driver is suitable for the job. Have you check
L298? It's a high voltage and current device with 2 H-bridge. Read the specs, I think it can take up to 2A.
May the force be with you.
My project: Simple White Line Follower
http://au.youtube.com/watch?v=8Z_MmrdH4oc
http://i271.photobucket.com/albums/j...nefollower.jpg
Wingmax is offline   Reply With Quote
Old 28th October 2007, 10:34 PM   (permalink)
He's already said it's from an electric drill - it will need a LOT more than 2A.
Old 28th October 2007, 11:28 PM   (permalink)
I don't know the requirement of his project, but if he hasn't got much to spend, may be he should use a smaller motor. If a smaller motor can do the job, then the motor itself is cheap and the driver components are also cheaper. If he has to use that motor, than may be there's no cheap solution.
Project: DC Motor Control (using a single switch) arijit18 Electronic Projects 12 2nd September 2008 07:51 PM
Driving a DC Motor with PIC Hesam Kamalan Robotics Chat 6 23rd October 2007 11:17 PM
Am I right about DC motor? bananasiong General Electronics Chat 3 15th October 2007 12:58 PM
Help: Mains Powered DC Motor bobledoux Electronic Projects Design/Ideas/Reviews 4 10th October 2007 09:30 PM
closed loop DC motor control vuchris Electronic Projects Design/Ideas/Reviews 0 30th September 2007 11:27 AM
