Old 17th October 2007, 03:21 AM   (permalink)
Cool In the works: MAX1
I am sad to announce that the pasta bot series has ended, because the names were kinda silly .
I wanted to come up with better names, and to start that off I have devised:
the MAX Series! MAX stands for:
Nothing! I just wanted to make it up! SOunds fancy and important
BUWHAHAHA! It is simple! So simple I could create it! Flawless!
MAX1 Will be a solar robot that will charge itself and walk. It will be covered in the solar blankets just to look fancy. I will explain more when I am not so tired.
Krumlink is offline   Reply With Quote
Old 17th October 2007, 05:30 AM   (permalink)
Yes, MAX sounds real good.
Wingmax is offline   Reply With Quote
Old 17th October 2007, 01:56 PM   (permalink)
MAX-1 sounds better than MIN-1
ronsimpson is offline   Reply With Quote
Old 17th October 2007, 06:22 PM   (permalink)
It will charge its battery for a couple of months then it will wake up and take two steps which will discharge its tiny battery. Then it will charge again for a couple of months.
That is outdoors. Indoors it will take years to charge its battery!
Old 17th October 2007, 07:16 PM   (permalink)
No it wouldnt.
1. You dont know what solar panel is charging it
2. You dont know what batteries I will use
3. You dont know what solar engine I will be using
I would wait and see
Old 17th October 2007, 08:06 PM   (permalink)
A huge and heavy one?
Huge and heavy ones?
It isn't an engine. It is a switch.
Old 17th October 2007, 08:22 PM   (permalink)
perhaps you could mount a light on top which is switched on and pointed at the solar panel when the level of charge drops too low!
monkeybiter is offline   Reply With Quote
Old 17th October 2007, 08:42 PM   (permalink)
1. No, a 3cm by 6cm one
2. Small, Tiny ones with awesome capacity for POWER!!!
3. I know its a switch, sounds more interesting.
Old 17th October 2007, 08:43 PM   (permalink)
Teeny weeny Solor bots usually use pager motors and spin on the axles.
Bill
Smart Kits build Smart People
Old 17th October 2007, 09:05 PM   (permalink)
Two of my solar garden lights have a solar panel exactly twice the size as yours. They have been outside in the sun all day today charging 2 AA Ni-Cad cells which will power the fading 3-colors LED for a couple of hours tonight.
In the middle of summer the LED is bright for about 8 hours.
Outside in the sun, your small solar panel will have a current of about 15mA at noon now in autumn. All day in the sun will produce about 30mAh. Not much to power two motors.
Old 17th October 2007, 09:07 PM   (permalink)
Too small to provide any decent amount of charge.
No, puny tiny ones, probably enough for what you want? - as long as you charge them from a decent source (not the tiny panel above).
And provides only a tiny pulse of power to move a tiny pager motor, like Audioguru said.
Old 17th October 2007, 09:34 PM   (permalink)
The calculated current comsumption of the walking robot under no load is 100ma. I was going to use 2 paralleled 3.6V 270mah Batteries (nicad rechargeables) for a total of 540mah. At a low current input of at least 60ma (the solar panels that I have in a very dim room, rated at 3V 50ma, they got 1.15V at 20ma ) that means it would charge the batteries in 9hrs. This is at worst case scenario, as I will have a simple pin connection to plug it in and out, so it will have selective power (AA or solar). This will work.
Old 17th October 2007, 09:46 PM   (permalink)
Doomed to failure!!!
Old 17th October 2007, 09:50 PM   (permalink)
A solar panel output of only 1.15V won't charge a 3.6V battery.
It is rated for 3V/50mA at noon in the sahara desert pointing directly at the sun, straight up. At other locations and times of the day the current is much less.
Old 17th October 2007, 09:52 PM   (permalink)
I know, I was going to put those 4 small ones in series and the bigger more ma one in parallel for more milliamps. Do you think it will work though?
My button works like magic, I only have to hover my finger over it jimfraseruk Micro Controllers 31 13th August 2007 07:42 AM
IR beam circuit - need to know how it works ant9985 General Electronics Chat 3 11th June 2006 12:53 PM
Randomness of 16F84 program - sometimes works somtimes doesn FusionITR Micro Controllers 10 28th February 2006 09:05 AM
what works in the simulator does not work on hardware??? spyghost Micro Controllers 7 26th May 2004 11:14 AM
How A Transistor Works windozeuser General Electronics Chat 0 28th November 2003 05:04 AM
