Experienced Member
I got a GWS mini servo motor. Has any one got the data for this motor?
Experienced Member
Try using google before asking questions in the forum, the following link took less than 5 seconds to find by searching for "GWS mini servo"
http://www.pololu.com/products/servos.html
Curiosity killed the cat; That's why they have nine lives.
Moderator
Love google, respect google, but dont work on the moon for google:
http://www.google.com/moon/
MechTronics |
Experienced Member
I have been to that site and many other sites before. But I need to know the pulse width range and frame rate, which I couldn't find. Usually they are between 1 to 2 ms. But it's not always the case. I also need to know the range of angle. I just thought someone out there might have experience with this motor. May be I have to assume the usual specs.
Experienced Member
yes, assume the usual specs and then experiment with it. There is a pretty wide range for hobby servos - even between 2 units with the same model number. I have a several GWS servos (different model number) converted to full rotation and I had to adjust the pulse length to each motor to get them to run at the same speed.
Experienced Member
You are so right. May be that's why they don't have that part of specs, the tolerance is too wide. May be that's why it's cheap. |
Super Moderator
Experienced Member
I think they should provide specs with tolerance. It's important to use the servo motor for positioning.
It the pulse width is 1ms to 2 ms for example, you'll expect at 1.5ms it's in mid position. At 1 ms or 2 ms it's on both end stops. If it's outside this range the motor will keep hitting the end stops and wears out the motor. If you experiment it for best result and you think you got the specs right and buy 100 more identical motors, if every one is different for a wide range, you'll waste so much time just because the manufacturer don't adhere to their product spec. |
Super Moderator
Experienced Member
Actually, Nigel, the feedback is also off on the GWSs. At least the cheaper line. I think it's also the case for most servos. The reason why it doesn't matter is that in the intended application (RC vehicles) the user adjusts the pulse width via joy stick. Thus, the "pilot" compensates for the gross inaccuracy of the servos.
They aren't used much in tandem except for robot drive like the common sumobot. Calibration/compensation is pretty easy to do so robot builders accept the problem as a minor annoyance to have cheap, compact, easy to interface motors. |
Experienced Member
Big model aircraft (like these: http://www.cactusaviation.com/Galler.../hamilton.html) also use multiple servos on the same flight surface. A variety of servo balancers are available. For example, here is just one version:
http://www.servocity.com/html/servo_synchronizer.html Besides the need to balance and match servos that are in tandem, one must also consider drift. Some servos, even the expensive ones, drift terribly with temperature. Thus, the match can change from day to day. John |
Experienced Member
wow, that is one big mofo model - any bigger and the FAA is going to come calling. I'm surprised how relatively cheap that balancer is.
Experienced Member
| Motor Controllers and serial comm? | RedCore | Micro Controllers | 18 | 3rd July 2007 01:27 AM |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 02:45 PM |
| Project: DC Motor Control (using a single switch) | arijit18 | Electronic Projects | 10 | 27th December 2006 06:03 AM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 09:23 AM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 02:55 AM |
