Old 30th September 2007, 05:10 PM   (permalink)
Question Corrections in the circuit
maheshcet is offline
Old 30th September 2007, 05:13 PM   (permalink)
i am using the given transmitter and receiver circuit for obstacle detection...
kindly suggest any problems associated with the circuit....
also i am looking for an addition to this which will enhance the range of the IR sensor... how about a darlington IC...
Old 30th September 2007, 05:15 PM   (permalink)
Why not put this in the other IR thread you started
Krumlink is offline
Old 30th September 2007, 05:16 PM   (permalink)
It's just a simple IR transmitter at 38kHz...
and the TSOP circuit receives it...
Old 30th September 2007, 05:17 PM   (permalink)
the TSOP is not responding to the IR from the transmitter....
and once it responded ,.. but the range was as low as. 10cm
Old 30th September 2007, 05:18 PM   (permalink)
my point is still valid
The 555 is total crap to output a good 38khz signal. A much better alternative is a schmitt trigger inverter oscilliator with very low tolerance parts.
Krumlink is offline
Old 30th September 2007, 05:19 PM   (permalink)
Most likely, because the IR signal is way too weak. Is this giving off a constant 38khz signal? if so, I would drop that massive 2.2kohm resistor down to 330 ohms for a much brighter signal display.
Krumlink is offline
Old 30th September 2007, 05:20 PM   (permalink)
can u also tell me ways of increasing the range of the IR transmitter..
Old 30th September 2007, 05:22 PM   (permalink)
hook up a transistor's base to the output of the 555 and put a small resistor across the LED or Base? I just told you one way, you dont need any more than the 555 is giving you! the 555 can output about 200ma! That is killer for a LED!
Krumlink is offline
Old 30th September 2007, 05:26 PM   (permalink)
i was thinkin to use a darlington .... to boost the current...
i think there is no need for that...
Old 30th September 2007, 05:28 PM   (permalink)
Most certainly not! 200ma is perfectly overkill!
Krumlink is offline
Old 30th September 2007, 08:06 PM   (permalink)
As suggested, a 555 isn't much use as you're not pulsing it - the IR detectors expect a pulsed signal.
Check my website at http://www.lpilsley.co.uk/cybot/radar.htm for probably just what you're looking for?.
Nigel Goodwin is online now
Old 1st October 2007, 02:14 AM   (permalink)
The 2.2k resistor in series with the IR diode limits its current to about only 1mA.
If the resistor's value is decreased to 30 ohms then the current and brightness is 50 times higher. If the duty-cycle is reduced then the current could be increased much higher and the 555 could drive a transistor to supply it.
The TSOP IR receiver IC reduces its gain if the 40kHz IR is continuous to reduce its sensitivity ti interference from compact fluorescent light bulbs. The 40khz IR should be modulated in bursts of data with a pause in between.
audioguru is online now
Old 1st October 2007, 03:18 AM   (permalink)
is there any mistake in the values of R and C used in my transmitter ? i mean for producing a 38kHz.... if there is a mistake kindly send the correct values
Old 1st October 2007, 12:50 PM   (permalink)
If the parts values are exact and if the pot is set exactly halfway then the frequency is 41.9kHz.
I don't know what tolerance the parts have so the frequency will be different.
Adjust the pot so the max amount of signal is received.
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 26 13th June 2005 06:07 PM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 10:45 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 03:06 AM
correction(s) to the 4-stepper circuit please ajay_kumar_d Electronic Projects Design/Ideas/Reviews 1 18th March 2004 08:21 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
