+ Reply to Thread
Results 1 to 3 of 3
Thread: Tamiya Gearbox bushings.
  1. #1
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,457
    Blog Entries
    11
    Default Tamiya Gearbox bushings.
    If you have not assembled a Tamiya gearbox you may not be interested in this post.
    While assembling a Tamiya double gearbox I noticed the grease used between the axle and brass bushing was quite stiff. Enough so that the bushing wanted to turn with the axle.
    Was I right about this. Perhaps a wee bit of super glue or even a bit of the grease on the outside of the bearing would keep it from turning in the case. Or may light machine oil to lube the axle.
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,670
    Blog Entries
    5
    I've started using very little grease with those gearboxes. I've also started using Tamiya Cermaic Grease instead of the stuff that comes with the gearboxes.
    Bill
    Smart Kits build Smart People
  3. #3
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,457
    Blog Entries
    11
    It seems you have learned quite a bit about these gearboxes. Thanks for sharing it.
+ Reply to Thread
  1. Opto sensors on a geartrain (Tamiya Double Gearbox)
    By blueroomelectronics in forum Robotics Chat
    Latest: 14th February 2009, 02:56 AM
  2. Tomiyama Gearbox and PWM
    By the dude of dudes in forum Robotics Chat
    Latest: 22nd July 2007, 10:10 PM
  3. L298 for 3V motors of tamiya dual gearbox ?
    By pkshima in forum Robotics Chat
    Latest: 13th June 2007, 05:11 AM
  4. Opto or Magnetic rotation sensor? (Tamiya Twin Gearbox)
    By William At MyBlueRoom in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th October 2006, 07:05 PM
  5. Wanted: Compact Gearbox!
    By MathGeek in forum Robotics Chat
    Latest: 16th September 2005, 04:06 AM
Tags for this Thread
