+ Reply to Thread
Page 3 of 3
First 1 2 3
Results 31 to 33 of 33
Thread: Clarification Ultrasonic Sensors..!!!
  1. #31
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,864
    Quote Originally Posted by Lesh
    Which graph? I think we are looking at different data sheets. TI and ST data sheets list a spec of 700khz min. ST does have a GBP to temperature graph.
    Which manufactures data sheet are you looking at?
    National Semi invented the LM358 so I look at their datasheet.
    ST Micro says that its GBP is 1.1MHz when it has a 5V supply, but its graph shows 1.1MHz with a 30V supply and only about 500KHz with a 10V to 15V supply. ST Micro frequently get things mixed up.
    TI says its GBP is only 700kHz typical when it has a 30V supply. No graphs.
  2. #32
    tippa Newbie
    Join Date
    Jan 2009
    Posts
    3
    i too want an receiver circuit for amplifying 40khz signal from GL402R receiver... i want amplified signal of max 5v what should be the gain and can i use LM358 for that...plz anyone provide me the circuit for that
  3. #33
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,864
    At 40kHz an LM358 has a max output level of only 3V p-p and a max gain of only 25 if the supply is between 10V and 15V. If the supply is 5V then it can hardly amplify 40kHz.
    An MC34071 single opamp, MC34072 dual opamp or MC34074 quad opamp) also have a minimum supply voltage of 3V and have inputs that work at ground in a single supply circuit but have full output level up to 100kHz and have a max gain at 40kHz of 200.
+ Reply to Thread
Page 3 of 3
First 1 2 3
  1. ultrasonic sensors
    By gut_but in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th March 2005, 12:36 AM
  2. Two sensors, one interrupt pin!!!
    By 2camjohn in forum General Electronics Chat
    Latest: 11th August 2004, 01:12 AM
  3. srf04 ultrasonic sensors
    By cjgalway1000 in forum Robotics Chat
    Latest: 5th March 2004, 04:55 PM
  4. ultrasonic sensors
    By gef1234 in forum Datasheet/Parts Requests
    Latest: 10th December 2003, 02:20 AM
  5. Ultrasonic
    By tindy in forum Datasheet/Parts Requests
    Latest: 6th October 2003, 03:47 AM
Tags for this Thread
