i need help with a belt drive drive train i cant find anything i found this site and i like that design but i want 4 wheels not 2
http://www.seattlerobotics.org/encoder/200104/wheel.htm |
does any1 know where i can get a wheel like that
He had the wheels custom made, it would cost $$$ to get that done.
Solid rubber wheels are more economical and suited for a battlebot. ![]() Last edited by blueroomelectronics; 25th August 2007 at 04:14 AM. |
well i like that type of drivetrain and i actually would like a belt drive like that that i can bolt to a flatproof tire
so does any1 know where i can get a beltdrive like that
You can have a motor assembly with a bunch of motors for a central drive chain, and drive the bot like a tank. You then hook up the motors to each of the wheels via chain or belt. Then do this for the other side. You can hook them up with belts and gears to get some major torque. That is how many FIRST robotics work. It is guaranteed to work well. You could also make a crab drive bot, but would probably break, but amazing maneuverability.
i know i am doing tank drive but im going to make it belt drive attached to the wheel to give it extra torque and im also attaching chain and sprockets
Perhaps these guys can be of assistance:
http://www.cncbotparts.com/ Or you could buy a featherweight kit (or its drive module separately) from these guys where the chain and all is already taken cared of http://www.battlekits.com/ Even though you said you want 4 wheels, I just point out featherweight because it's way way cheaper (and comes with armor!) than the other larger (4-wheel) kits. THe drive you linked though would get smashed to bits in a battlebot (and cost magnitudes more to replace). It is possible to get flatproof, belt/chain driven tires without having to go to all that trouble. Personally I prefer gearboxes over belts and chains...just because. Last edited by dknguyen; 29th August 2007 at 03:12 PM. |
I'm sure magee will run out and buy one for $1200US
Our half million dollar automated plating line uses standard bicycle size chain for both of it's main drive wheels and heavy duty double chain from the main motor to a reduction gear. You might want to re-think your chain prejudice dk as it's unfounded =) Chains are signifcantly more robust than gears in many situations. The smaller chain has broken only twice and that was because of a worn sprocket, and the double wide heavy duty chain has never needed anything other than occasional greasing.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
You can get battery operated mountain bike transmissions which you could use as a microcontroller controlled automatic transmission. If the motor starts to work too hard and draw too much current then you change down a gear to give you even more torque and if it's not working hard enough you can change up a gear to give you more speed. This will give you both speed and pulling power.
wow thats a good idea hero 999 do u know where i can get on of those or how i would wirelessly get that hooked to my controller
If you need something compact I'd recommend an RC car transmission. A mountain bike's derailer is pretty bulky. A visit to your local hobby shop should present you with some sollutions.
would an rc transmision even last in a battlebot middleweight competition
Would a bicycle transmission?
| mini battle bots weapon ideas. | war_god | Robotics Chat | 8 | 24th August 2007 03:22 PM |
| Battle Bots? help plz. | hamm3rst0rm | Robotics Chat | 4 | 17th August 2007 02:43 PM |
| need help with a bot project | sal | Robotics Chat | 10 | 25th January 2007 10:48 PM |
| mini battle bots weapon ideas | war_god | Electronic Projects Design/Ideas/Reviews | 1 | 21st January 2005 07:06 PM |
