Old 8th August 2007, 02:09 PM   (permalink)
Default Mongoose Mechatronic Chassis first production photos
Here are photos of the first production version of the Mongoose.
Front (note the standoffs plus top & forward mounted connectors for your own PCBs or future kits)
Underside (TTL Serial connector, thermal fuse and a good look at the ball caster)
Rear (note the ballcaster & 0.1uf caps on the motors if you look carefully you can even see the painted rotation sensor stripes on the blue front gears, it's also starting to rain
Bill
Smart Kits build Smart People
Old 8th August 2007, 04:41 PM   (permalink)
Very nice. I was wondering why did you mount the pcb to the the front and not the top? The only reason I ask is that there doesn't seem to be much clearance from the pcb to the ground.
Bryan76 is offline
Old 9th August 2007, 05:34 PM   (permalink)
The front mounted PCB is 7.6mm (.3") from the floor. The top was reserved for a breadboard or other user options. There is also a front mounted I/O and mount points for user PCB designs like rangefinders, line followers (where being close to the floor is nessary). It's designed for flat indoor surfaces.
Bill
Old 9th August 2007, 06:47 PM   (permalink)
10-4, keep up the good work!
Bryan76 is offline
Old 9th August 2007, 09:42 PM   (permalink)
Very nice! you finally finished the bugger. Nice work.
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 10th August 2007, 12:55 AM   (permalink)
Which parts/components did you actually make Bill. Are the motors and gears and housing a standard part or did you design and build that/those components?
Looks very nice...
Mike, K8LH is offline
Old 10th August 2007, 01:13 AM   (permalink)
All the motors, gears and wheels are made by Tamiya. Most hobby stores should be able to get them.
They are very high quality and not terribly expensive.
Tamiya double gearbox includes motors and gear grease, Mongoose uses the 115:1 ratio setup. Those square holes in the front are ideal for the opto sensor set. (they need only a little enlarging) #70168
Tamiya 58mm Wheels & tires #70145
Tamiya ball caster #70144
Bill
Old 10th August 2007, 03:44 AM   (permalink)
Robot builder 101
Would I just give my local hobbystore these part numbers?
Old 10th August 2007, 04:21 AM   (permalink)
Yep, those are the Tamiya part numbers. Any hobby store that sells Tamiya models should be able to order them.
Bill
Old 10th August 2007, 05:07 AM   (permalink)
Robot builder 101
Oh, well theres the problem. They dont sell any tamiya model stuff.
Old 10th August 2007, 05:13 AM   (permalink)
You won't get very far if you limit yourself to one store.
Pommie is online now
Old 10th August 2007, 05:16 AM   (permalink)
Bill,
It looks very nice. Can I just ask, where on earth did you get that right angled sil socket?
Any plans for add on sensor boards?
Old 10th August 2007, 05:28 AM   (permalink)
Robot builder 101
Jameco!!!
https://www.jameco.com/webapp/wcs/st...roductId=71160
Old 10th August 2007, 02:16 PM   (permalink)
Originally Posted by Pommie
Bill,
Lucky for me Creatron in Toronto has little difficulty getting almost any part.
I'm a little stumped on Ethernet jacks with magnetics for the next kit.
As for a hobby store without Tamiya, try an RC store. Tamiya is a huge company.
Bill
Old 10th August 2007, 03:26 PM   (permalink)
nice work with the robot - looks like a great platform to experiment with.
regarding the jacks with integerated magnetics, the supplier that comes to mind is Pulse and their MagJack product.
Mouser has the Pulse J0026D21 for $3.49 ... Pulse seems to have a lot of options for the jack with different internal magnetic and wiring configurations, I'm not sure what is normal or what is required by your PHY.
here is the datasheet, I think they've got direct link protection in place, so this link may not work, in that case just visit the website directly and plug the number into the search box.
http://www.pulseeng.com/products/datasheets/J403.pdf
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
