| New Member | i am currently a student who is working on the h-bridge with L298 ic. This h-bridge is going to run 2 dc gear motor with 12v and 1.1A. I followed the circuit diagram from this website below. http://www.dprg.org/projects/1998-04a/ However,this website didnt tell me what is the code for the diode. My friend recomment me to use either IN4001 or FR202. Which 1 will be suitable. Is there anything i need to modify on this circuit diagram that i found? |
| Experienced Member | hi katew, Looking at the link and knowing the size of your motor, I would say any general purpose 1Amp 100Vpiv rectifier would be OK. [1N4001]
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
| New Member | Quote:
| Experienced Member | Quote:
The website text warning NOT to drive both sides of the 'H' at the same time are important, else you will damage it. http://www.dprg.org/tutorials/1998-04a/
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| Experienced Member | If you current limit the power supply then it's possible to do it safely but I wouldn't if that isn't the case. |
| New Member | Quote:
| New Member | Quote:
| Super Moderator | Quote:
| New Member | if i wanted to add in resistor to the circuit,to protect the circuit. which part do i need to add in? |
| New Member | hving problem with the circuit...not so sure what it is the 2 hole between the diode and the holes for the L298 IC |
| Experienced Member | hi katew, Attached drawing marking the two holes you are asking about, are these the two??
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:20 AM. |
| New Member | ya...is that 2 holes... |
| New Member | Hey I'm a new member in this forum..... best regards,.. |
| Experienced Member | hi katew, From what I can see from the project data, these two holes do not have any components fitted, they appear to be artwork pads used as a transition between a 'wide' track and a 'narrow' track. Normally the artworker would use a 'blind' pad [no hole] in this position, he appears to have used a 'doughnut' style pad [hole]
| Experienced Member | hi prasetyo, Welcome I hope you enjoy the forum. I would suggest that you examine the different forum topics/headings, so that you can post any future posts in the correct forum. In this way, you will get the best response and attention to any questions you may have.
| L298 H Bridge. | lord loh. | General Electronics Chat | 3 | 31st May 2006 11:15 AM |
| h bridge problem | bananasiong | Electronic Projects Design/Ideas/Reviews | 28 | 28th March 2006 03:37 PM |
| L298 Back EMF | pittuck | General Electronics Chat | 16 | 20th November 2004 03:15 PM |
| full-wave bridge rectifier problem | MsStateDawg | Electronic Projects Design/Ideas/Reviews | 12 | 5th January 2004 06:52 PM |
| bridge amplifier problem | l_ugavante | Electronic Projects Design/Ideas/Reviews | 1 | 18th August 2003 03:36 AM |
