| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | If you connect a large electrolytic capacitor from the power supply output that your drill will use, to the power supply's ground (note the correct polarity for an electrolytic, and use one with a voltage rating that's higher than your supply voltage), the cap will already be charged when you turn on the drill. The capacitor's stored charge will help supply any current surge that the drill demands from the supply. If the capacitor was large-enough, and could respond fast-enough, the supply might not see the surge demand at all. If you have trouble getting it to work, you might want to try using several large-ish capacitors in parallel, instead of just one. In this type of testing, I don't think some inital amount of overkill could be a bad thing (unless you get to the point where the capacitors' demands during charging cause the power supply to shut down, or be damaged). So, if you can scrounge some quite-large capacitors from the power supply of a dead monitor, or computer, or whatever, or otherwise acquire them, you could try using some tens of thousands of microfarads (uF), to start with. If you do get it to work, you can then figure out what minimum capacitance seems to be needed for reliable operation, and add some margin to that to try to make life easier for the power supply. Also, which PSU output are you using? The 15V? I think that some computer (and some SMPS types, in general) need to have some minimum load on them, all the time, to operate correctly. It MIGHT even be the case that your drill-startup problem is more-related to THAT, rather than to trying to draw too large of a current spike. I'm not sure that that is probable-enough to even be worth mentioning, but, in case the capacitor _doesn't_ solve your problem, then maybe you would want to also try the following. You might be able to tell what minimum load is needed from the specs on the label, or look it up on the web, somewhere, for your make and model. At any rate, you might need to put a small power resistor on the 5V supply (or 3.3V if you have that), since that's usually the "master" one, which needs to always have a load, if your supply is one of those that does need that. I have no idea what amount of current you might need to draw, in that case. It might be a couple percent of the 5V supply's rated current. Maybe try a resistor that would pull about 1 Amp, for a first try, since you could then use a common cement power resistor of about 5 Ohms, rated for say 10 Watts or 15 Watts (since it will dissipate 5 Watts, if it's 5 Ohms and draws 1 Amp with 5V across it, and a 5 Watt one would get very hot, then). If you get two or three of the 15 Watt ones, and it doesn't help with just one of them, you could try two in parallel, or three in parallel, to draw more current. If one works, though, then you could try using more ohms, to get less current, and less heat and waste. So then you could try putting them in series. The currents and resistance I gave were just a totally-wild guess (hopefully on the overkill side, to raise the probability of a correct diagnosis on the first try). So if some minimum load does turn out to be required, you'd want to find the largest resistance that gave reliable operation, and would probably want to end up with one properly-sized resistor with an appropriate power rating etc, and maybe a heatsink (like the case of the PSU, possibly, if you can insulate the leads well-enough). Good luck. - Tom Gootee http://www.fullnet.com/~tomg/index.html - |
| Experienced Member | It's the sudden load that's the problem. PC PSU's work based on the increase in current to trigger it's safety off, basically meaning you can go from 1amp to 20 amps just fine, but if you do it too fast the power supply trips it's safety shut off. If you place a heavy power resistor in series with the positive power lead of the power supply, and the capacitor/capacitor bank in parallel on the other side (toward the load) of it the power resistor will limit the maximum current by brute force (wasting some as heat) if the capacitor is charged though It can provide huge amounts of pulse currents to the load side for short periods for starting your motor, while it will gradually charge back up to working voltage through the resistor. If you need a schematic it's pretty simple. http://en.wikipedia.org/wiki/Low_pass_filter The hard part is the load resistor as to be useful it needs to be relatively high to limit rush current but it will also cause a voltage drop. I know of some PSU's that have external 3.3V sense lines but none that have 12 volt sense lines so the resistor is going to drop voltage. If you get past though point where you can use a low pass filter like that to avoid the trip, you probably need to learn how to design your own power supply.
__________________ Curiosity killed the cat; That's why they have nine lives. Last edited by Sceadwian : 18th May 2007 at 03:33 AM. |
| Experienced Member | Quote:
Yes, that all sounds exactly right. (Sorry, Hank! I should have suggested that! I must not have gotten enough sleep, the night before.) I've used thermistors, similarly, just before the filter cap in a power supply, for example. Unfortunately, a thermistor probably wouldn't work, in this case, because it wouldn't cool fast enough to prevent the problem if the drill was turned off and back on. The minimum resistor value and power rating could be calculated, knowing the currents and the capacitor's specs. But I guess if he's using something over 10000 uF, he could just experiment with resistances from 0.5 to 5 or 10 Ohms, as a rough guess, and go up or down from there until it worked. The resistor's power rating should only need to cover the steady-state case, since the surge should be short-enough to not worry too much about it, although some resistors' data sheets do give the data that would be needed to make sure it was also OK for the surge. He should use the smallest resistor that will solve the problem. And that will also have the lowest required power rating. There's one thing I still don't understand: Why did it work OK when he started the PSU with the drill already turned on? Is it maybe just a "feature" of the PSU's protection circuitry? - Tom Gootee http://www.fullnet.com/~tomg/index.html - | |
| Stabilised Power Supply with Current Limiting | mechie | Electronic Projects | 36 | 11th March 2008 07:16 PM |
| Current source | GagoX | Electronic Projects Design/Ideas/Reviews | 13 | 12th January 2008 06:32 PM |
| Magnets and Electromagnets | ElectroMaster | Electronic Theory | 11 | 27th November 2007 02:31 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 12:50 PM |
